bcondrey
Posted: Thu Jul 27, 2006 2:15 pm Post subject: OSH Engine Info |
As I noted in a prior post there really is very little here in the way of engine news. Several people have expressed interest in pictures so I've attached a collection.
At the risk of repeating myself, here are a few comments about what I've seen so far.
EMag/PMag: Hoping to flight test 6 cylinder version in the spring and have them at OSH next year. No other info available but they appear to be getting tired of being asked about it.
Mistral: Engines look good but no real delivery info. Big thing they were pushing is that each cylinder has dual injectors "in case one fails". Pictures attached of both models along with their rotor display.
Innodyne: Don't even have their own booth this year - they seem to be doubled up with one of the bush plane kit manufacturers. Picture attached of their entire display along with a closeup of the nose section of the engine with rust on the prop flange.
Deltahawk: They are displaying inside and talking about deliveries "next year". No picture attached.
Suburu: Only engine is the one in the demo plane. I asked about the RV-10 setup and they said "next year". Picture attached of their display space.
I also took a picture of yet another possibility but you might have to extend the cowl a bit. Engine is compression ignition and generates 350 HP.
62.36 KB |
483 Time(s) |
66.77 KB |
423 Time(s) |
67.99 KB |
451 Time(s) |
40.93 KB |
412 Time(s) |
58.5 KB |
430 Time(s) |
63.22 KB |
449 Time(s) |
57.3 KB |
449 Time(s) |
85.46 KB |
439 Time(s) |
pascalreid(at)verizon.net Guest
Posted: Thu Jul 27, 2006 5:03 pm Post subject: OSH Engine Info |
Thanks for the info and pictures.
The more I here about the "other" engine options the more Lycoming sounds
like a better choice.
At least I know it's been tested and is shipping!
Appreciate the comparo.
Pascal
toaster73(at)earthlink.ne Guest
Posted: Thu Jul 27, 2006 6:15 pm Post subject: OSH Engine Info |
I'll add another thanks for the updates... How about ECI's experimental 540?
Any new news on that?
Chris Lucas
#40072
bcondrey
Posted: Fri Jul 28, 2006 9:39 am Post subject: OSH Engine Info |
Just talked to them - they say it should be ready to show and ship by next summer at OSH.
Bob
Sent from my BlackBerry Wireless Handheld
rvbuilder(at)sausen.net Guest
Posted: Mon Jul 31, 2006 7:01 am Post subject: OSH Engine Info |
One thing I will add about the Mistral is that they did tell me that the
smaller two rotor engines are available now and their current goal is
certification. Three rotor model was probably next year. YMMV. The
smaller two rotor turbocharged 230HP would probably be a good fit for
the -10.
Michael
Posted: Mon Jul 31, 2006 7:54 am Post subject: OSH Engine Info |
There is already one person in Denmark putting the 230 in his RV-10. If you
look at engine it gives his opinion of the factory tour, if you look at
"updates" you'll get the engine delivery status.
http://www.rv10.dk/rv10/rv/defaulte.htm
Posted: Mon Jul 31, 2006 8:30 am Post subject: OSH Engine Info |
Interesting read. Update is a little old so I wonder if he has received
an engine yet? Based on some of the comments from other guys that
visited their tent, I must have got lucky as the guy I talked to was
fairly chatty.
Michael
LloydDR(at)wernerco.com Guest
Posted: Mon Jul 31, 2006 12:27 pm Post subject: OSH Engine Info |
Did they have the Dyno reports and fuel flow proof that you have asked
for from others?
Dan Lloyd
40269 (N289DT)
Tongue in cheek comment
