removing aerothane
occom(at)ns.sympatico.ca
PostPosted: Wed Jul 26, 2006 7:24 am    Post subject: removing aerothane Reply with quote
I have a couple of areas where the fabric must be repaired after it was cut away to assess the structure underneath.  In some cases it's just as easy to replace the whole area, but on some such as the tail area below the stabilizer I want to patch it. The Polyfiber manual says to sand off the aerothane, technique is probably important, anybody engaged in this activity?
Here is a picture of the affected areas.
 Filesize:  572.94 KB
 Viewed:  369 Time(s)
kitfoxpilot(at)msn.com
PostPosted: Wed Jul 26, 2006 11:35 am    Post subject: removing aerothane Reply with quote
This is how I removed aerothane for a tube repair! first you use any
hardware store paint stripper, brush it on but don't turn your back it works
fast. The paint stripper will soften up the aerothane so you can scrape the
aerothane off. next you will have to clean the bare fabric then reglue new
fabric on and paint. now make sure you use white paint over the silver so
that your yellow will blend good. I have photos of my repair if you like.
Ray
Subject: removing aerothane
Date: Wed, 26 Jul 2006 12:21:47 -0300
activity?
<< kitfoxwing012.jpg >>
PostPosted: Wed Jul 26, 2006 12:31 pm    Post subject: removing aerothane Reply with quote
Thanks Ray, and also Jeff who replied offline. I'll try it with the old MEK
(which by the way is the same mix of MEK, toluene and another that the loacl
auto paint store sells) and a paint remover this weekend. I'm learning to
dislike aerothane, if I had built new I would certainly go with polytone.
PostPosted: Wed Jul 26, 2006 12:54 pm    Post subject: removing aerothane Reply with quote
Aerothane is a pain to repair, but sure looks nice! forgot to tell you,
while your using the pain stripper, make sure the fabric does not roll up on
you. I used a small block of wood under the fabric while I was removing the
old aerothane.
[quote]From: "Dave G." <occom(at)ns.sympatico.ca>
Subject: Re: removing aerothane
Date: Wed, 26 Jul 2006 17:30:17 -0300
loacl auto paint store sells) and a paint remover this weekend. I'm
learning to dislike aerothane, if I had built new I would certainly go with
polytone.
PostPosted: Wed Jul 26, 2006 1:30 pm    Post subject: removing aerothane Reply with quote
Thanks Ray, feel free to send pics directly to me if you have time. I'd love
to see them.
pulsair(at)mindspring.com
PostPosted: Wed Jul 26, 2006 5:35 pm    Post subject: removing aerothane Reply with quote
If you are using MEK make sure you wear gloves and a respirator. That stuff
can be absorbed through the skin and kill ya. Jeff
lcfitt(at)sbcglobal.net
PostPosted: Wed Jul 26, 2006 7:26 pm    Post subject: removing aerothane Reply with quote
Jeff, respectfully I would suggest that your comments could be classified
as an urban legend. See:
http://www.epa.gov/ttn/uatw/hlthef/methylet.html
For the EPA scoop.
Lowell
