roncarolnikko(at)hotmail. Guest
Posted: Tue Jul 25, 2006 11:52 am Post subject: rpm cruise?/VW |
Hi Mark I'm only taxi testing my 1915cc VW, but my target static wot is
3400 rpm with an expected cruise of 3000-3200 rpm. Redline is ~3600 rpm. I
believe Revmaster or Great plains have rpm ranges posted. I just feel the
engine will not be comfortable below these rpms if pitched to steep. Of
course my redrive changes the prop I can run, but the engine is the same.
Can you rig a scale to the tail spring to get a static thrust? Ron NB Ore
| Quote: | From: "Mark Thompson" <kr2(at)earthlink.net>
Subject: rpm cruise?
Date: Tue, 25 Jul 2006 06:40:42 -0400
Anyone out there running a VW?,Do you run at cruise at a higher rpm than
2500 ?,can I run at 2900-3200 at cruise.I know other engines guys run a
feww hundred rpm lower than their max redline,but does this also apply to a
VW ?
Thanks for any ideas in this area.......................
ps I have attached a picture of my completed bird,another member of the fox
family.....
Sincerely Mark Thomson N61AC
Mark Thompson
EarthLink Revolves Around You.
| Quote: | << 2006_0710kitfox0004.JPG >>
Is your PC infected? Get a FREE online computer virus scan from McAfeeŽ
