dhkey(at)msn.com Guest
Posted: Mon Jul 24, 2006 8:53 pm Post subject: Throttle to Cable Question... all models |
There is a tiny hole that I'm suppose to use to connect my throttle stick to
the cable. I guess I'm suppose to use a safty wire or a cotter pin. What
have you guys done here?
Almost Done David
Description: |
Filesize: |
1.51 MB |
Viewed: |
312 Time(s) |
WillUribe(at)aol.com Guest
Posted: Mon Jul 24, 2006 9:16 pm Post subject: Throttle to Cable Question... all models |
I use a cotter pin
http://members.aol.com/cesaru/KolbFSII/259.jpg
In a message dated 7/24/2006 10:58:03 P.M. Mountain Daylight Time, dhkey(at)msn.com writes:
Quote: | There is a tiny hole that I'm suppose to use to connect my throttle stick to
Almost Done David |
John Cooley
Joined: 10 Jan 2006 Posts: 17 Location: Lucedale, Ms.
Posted: Tue Jul 25, 2006 3:01 am Post subject: Throttle to Cable Question... all models |
Cotter pin for me too.
Take Care,
John Cooley
Subject: Throttle to Cable Question... all models
Almost Done David
7/24/2006
_________________ Be Safe,
John Cooley |
ElleryWeld(at)aol.com Guest
Posted: Tue Jul 25, 2006 8:30 am Post subject: Throttle to Cable Question... all models |
That don't look like a good idea Your throttle cable is going to fail sooner or later because of where it is bending in the pic
Dont ask me how I know this
I replaced the throttle with a Quadrant from CPS California Power Systems I did a little mod to it but it is much better and less wear on the cable
heres a pic of it
Ellery in Maine
Description: |
Filesize: |
21.43 KB |
Viewed: |
293 Time(s) |
eagle1(at)commspeed.net Guest
Posted: Tue Jul 25, 2006 8:57 am Post subject: Throttle to Cable Question... all models |
A cotter pin comes with the kit for that purpose, However I would recommend
that you use a piece of piano (steel) wire bent over on both sides. The
reason being, If that LITTLE cotter pin breaks or wears out your throttle
goes closed.
Just my thoughts.
Az Bald Eagle
Posted: Sun Jul 30, 2006 1:16 pm Post subject: Throttle to Cable Question... all models |
| Thanks,
| Almost Done David
David/All:
I drill out that tiny hole to 3/32". Then use a 3/32" A&E clevis pin.
They are intended for this purpose. The cotter pin is not.
There was a gentleman that broke his Twinstar because of a broken
cotter pin in the throttle.
The 3/32" clevis pin can be purchased at most aviation hardware
sources.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Jul 30, 2006 1:24 pm Post subject: Throttle to Cable Question... all models |
fail sooner
| Ellery in Maine
Ellery/Gang:
I have found nothing wrong with the standard Kolb throttle, which I
have used for a good period of time.
I do replace my throttle cable every 500 to 600 hours as a precaution.
I also replace the cotter pin with a 3/32" clevis pin.
mkIIl
Titus, Alabama |
