rocky1(at)moment.net Guest
Posted: Thu Jul 20, 2006 12:38 pm Post subject: Angle of Attack |
Does anyone know the approximate angle of attack for a Series 7 at level cruise, 912s.
This is for the purpose of mounting a remote compass.
Rocky Whitman
barry(at)pgtc.com Guest
Posted: Thu Jul 20, 2006 1:28 pm Post subject: Angle of Attack |
Rocky
It is a function of weight distribution among other things, but basically it is a variable. You should be able to assume that it is level with the bottom of the door cut out. I don't know much about remote compasses but it must be able to handle some variation in attitude. It should be accurate when the tail wheel is on the ground.
Barry West
From: Denise and Rocky Whitman (rocky1(at)moment.net)
| Quote: | To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Thursday, July 20, 2006 3:34 PM
Subject: Angle of Attack
Rocky Whitman
wingsdown(at)comcast.net Guest
Posted: Thu Jul 20, 2006 2:59 pm Post subject: Angle of Attack |
Your AOA is going to vary with speed and load. Not trying to be smart, just a thought.
Rick
Aerobatics(at)aol.com Guest
Posted: Thu Jul 20, 2006 3:28 pm Post subject: Angle of Attack |
In a message dated 7/20/2006 6:01:18 P.M. Central Daylight Time, wingsdown(at)comcast.net writes:
| Quote: | Your AOA is going to vary with speed and load. Not trying to be smart, just a thought.
Rick
Here is an APROX that should be close....?
from the center of the leading edge to trailing edge will be your zero, then at about 3 or 4 degrees, you should be darn close....
Dave
kerrjohna(at)comcast.net Guest
Posted: Fri Jul 21, 2006 7:19 am Post subject: Angle of Attack |
If you are installing the Dynon unit I believe that you are to use the a/c datum which in this case is the door bottom tube.
John Kerr
| Quote: | -------------- Original message --------------
Rocky
Barry West
Rocky Whitman
Float Flyr
Posted: Fri Jul 21, 2006 4:40 pm Post subject: Angle of Attack |
What type of compass?? Fluxgate??
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
