Dumb question (another)
Deems Davis
PostPosted: Tue Jul 18, 2006 11:32 am    Post subject: Dumb question (another) Reply with quote
OK I'm going to expose my ignorance yet one more time. I'm still
planning my electrical/panel installation and I recall seeing pictures
of some device that I believe was a part of the electrical system that
was encased in plastic and mounted on the firewall/sub-panel (sorry
that's as descriptive as I can recall) I can't recall what the device's
function was or what it was called, but somewhere in the crevesases of
my mind, I filled a 'I need one of those' and now that I'm into the
planning/ordering, I have this uneasy feling that I'm missing something.
Can someone help me out?
Deems Davis # 406
Fuse
http://deemsrv10.com/
Tdawson(at)avidyne.com
PostPosted: Tue Jul 18, 2006 11:41 am    Post subject: Dumb question (another) Reply with quote
ANL current-limiting device (a.k.a. big-a** fuse). These look like
"blades" and can be held in an open holder, or a plastic enclosed
holder. Car stereo outfits sell all kinds of cool plastic enclosures,
or B&C sells the basic open holder. Under the cowl, I'd go with the
enclosed holder. (or you could build an aluminum enclosure if you were
so inclined.)
TDT
Deems Davis
PostPosted: Tue Jul 18, 2006 12:23 pm    Post subject: Dumb question (another) Reply with quote
Great!
Where are they used? What determined whether or not they are needed?
THANKS
Deems
so inclined.)
TDT
Deems Davis
PostPosted: Tue Jul 18, 2006 12:42 pm    Post subject: Dumb question (another) Reply with quote
Never mind, I found the answer in My Aero Electric manual
Deems Davis wrote:
Great!
Tim(at)MyRV10.com
PostPosted: Tue Jul 18, 2006 2:26 pm    Post subject: Dumb question (another) Reply with quote
Deems,
Not sure if this is what you're referring to, but if it's
the thing on this page:
http://www.myrv10.com/N104CD/panel/20060115/index.html
..then that's my ANL fuse.
Is that it?
I think Michael Sausen just mentioned them today.
Deems Davis # 406
Fuse
Deems Davis
PostPosted: Tue Jul 18, 2006 2:41 pm    Post subject: Dumb question (another) Reply with quote
That's it
THANKS
Deems
Tim Olson wrote:
Deems,
...then that's my ANL fuse.
Is that it?
wcurtis(at)core.com
PostPosted: Tue Jul 18, 2006 4:05 pm    Post subject: Dumb question (another) Reply with quote
You sure this was an ANL fuse an not an Essential Bus Diode? This is used to prevent the drain of an Essential Bus Battery by non-essential bus devices in the event of a main alternator or battery failure. >Where are they used? What determined whether or not they are needed? > >THANKS > >Deems > >Tim Dawson-Townsend wrote: > >> >> >> >>ANL current-limiting device (a.k.a. big-a** fuse). These look like >>"blades" and can be held in an open holder, or a plastic enclosed >>holder. William 40237 - SB Fuselage http://nerv10.com/
