goodings(at)yorku.ca Guest
Posted: Mon Jul 17, 2006 1:54 pm Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
After flying our CH601HD with Rotax 912S (100 hours) last weekend, we had
occasion to pull the prop through by hand. When pulled quickly, a squeak
was heard from the front of the engine; the engine was hot. When we ran
the engine again after lunch, the squeak was heard again for the last
couple of blade rotations before the prop stopped. We had heard from an
expert AME on Rotax engines that a few certified 912S engines had been
assembled with an incorrect part in the slipper clutch in the gear box.
(The mating surfaces of the clutch hub and the dog gear should both have
an angle of 7 degrees, whereas one of the parts in the faulty assemblies
had an angle of 0 degrees, meeting the other part at the wrong angle.)
There was the possibility that some uncertified engines like ours had
suffered a similar fate. Thus, our gear box was opened up by the expert
AME; however, the correct parts had been installed. It was reassembled by
him (with great care; it had to sit overnight for the correct Loctite
sealant to set). When the engine was run approximately 40 hours later,
the squeak had disappeared. We would be interested to learn if any other
912S users have encountered this characteristic squeak. If so, were they
able to determine a clear-cut cause?
John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Waterloo.
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
NYTerminat(at)aol.com Guest
Posted: Tue Jul 18, 2006 5:56 pm Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
I have the squeak upon shutdown, sounds like short a fan belt squeal.
Bob Spudis
N701ZX / Zenith CH-701/912S
In a message dated 7/17/2006 5:55:12 P.M. Eastern Daylight Time, goodings(at)yorku.ca writes:
ami(at)MCFADYEAN.FREESERV Guest
Posted: Wed Jul 19, 2006 1:25 pm Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
I've had the squeak for 300 hours; either when pulling the prop trough by
hand or on shutdown. I'm pretty sure it is the dog clutch (i.e. NOT the
slipper clutch) that produces this.
I complained to my local Rotax agent when it was new. He said I was just a
trouble maker! This is the level of service that can be expected from
Rotax's illegal and anti-competitive policy of 'one Country, one Agent'.
Duncan McF.
paul.mitchell2(at)homecal Guest
Posted: Thu Jul 20, 2006 12:37 am Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
My 20 hour old engine has the same squeak under all those conditions. I was
also told that was "How they are" I also had other concerns. It took the
intervention of the MD from the aircraft manufacturer in Italy direct to
Rotax in Austria to get the Agent in UK to even come and look. After the
intervention, a really positive visit took place. I now have a much sweeter
engine with a squeak.
Paul Mitchell
Posted: Thu Jul 20, 2006 8:17 am Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
Paul,
Thanks for your reply, I am glad that I am not alone with the squeak. I have forwarded these e-mails to Lockwood and will post their reply.
Bob Spudis
N701ZX CH701/912ULS
awaiting intervention
In a message dated 7/20/2006 4:39:45 A.M. Eastern Daylight Time, paul.mitchell2(at)homecall.co.uk writes:
Quote: | --> RotaxEngines-List message posted by: "MR PAUL MITCHELL" <paul.mitchell2(at)homecall.co.uk>
Paul Mitchell
Posted: Thu Jul 20, 2006 12:17 pm Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
Paul,
May we benefit from the knowledge of what was otherwise done to make your
engine much sweeter?
Duncan McF.
Posted: Mon Jul 31, 2006 2:27 am Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
Duncan,
Sorry for the delay in replying
Carb balance, (factory set slow running stops out) also slow running
mixture. I have just spent a week at Glenforsa on Mull and did the flight
home to Hinton in the Hedges with a tea stop at Carlisle in 3hrs 55mins
airtime on 55 litters at 110knots against a 10knot headwind. The engine is
in a Tecnam Sierra.
(Squeak still there.)
Paul
Posted: Tue Aug 01, 2006 9:47 am Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
Paul,
Thanks.
What method did you use to get the idle mixture correct? (i.e. ear, lambda
probe, other?).
Rgds.,
Duncan.
Posted: Wed Aug 02, 2006 2:27 am Post subject: RotaxEngines-List Digest: Squeak on Rotax 912S |
Duncan,
Conrad Beale of Conairsports did it by ear. Not scientific but it works
Paul
