shilocom(at)mcmsys.com Guest
Posted: Wed Jul 19, 2006 3:20 am Post subject: sloshes |
I'm in need of a fuel tank sealant on a metal tank using diesel fuel, NOT on an airplane and a very slow leak. What would the experts suggest
Blue Skies
Bob Unternaehrer
shilocom(at)mcmsys.com (shilocom(at)mcmsys.com)
noelloveys(at)yahoo.ca Guest
Posted: Wed Jul 19, 2006 6:21 am Post subject: sloshes |
Proseal... its used on TC cat aircraft like the metroliner to seal the tanks form the inside. Particularly dirty to work with/;^}
Noel [quote]
Posted: Wed Jul 19, 2006 1:32 pm Post subject: sloshes |
This tank is an already enclosed tank which the biggest access about a 2" dia neck. Can I just clean tank with ????? muratic acid or something and pour the suff in... If so how much. The tank is only leaking on the bottom, which is about 10" wide by 48" long. Bob U.
bmwebb(at)cox.net Guest
Posted: Wed Jul 19, 2006 4:07 pm Post subject: sloshes |
Did you manually “slather” it on? I can’t see it being allowed to slosh. Unless you reduced it with something.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Wednesday, July 19, 2006 10:21 AM
Subject: RE: sloshes
Noel [quote]
