Question about XL lower nose gear support bolts
deglass1(at)aol.com
PostPosted: Sat Jul 15, 2006 7:33 pm    Post subject: Question about XL lower nose gear support bolts Reply with quote
This might be obvious, but is an unusual design practice -
The 4 bolts AN4H-5A that mount the lower nose gear bearing support 6B8-9 to the nylon bearing appear to require a blind, threaded hole into the nylon block, then they're safety wired to prevent backout.  The bolt length appears to support this, but depending on threaded plastic for pullout strength doesn't sound like good practice without an anchor insert.
Please advise - are these bolts just threaded into the nylon, and is this OK since there won't be any (or not much) pullout force or shock?
Thanks for all the help this list gives all of us!
David Glass
Forest (near Lynchburg), VA
N253DG reserved
XL fuse, finally finishing the airframe
nfivesl(at)YAHOO.COM
PostPosted: Mon Jul 17, 2006 4:44 am    Post subject: Question about XL lower nose gear support bolts Reply with quote
David:
I countersunk mine from the top and bolted them all
the way through with nuts on the bottom. Here's a veiw
from below showing the nuts on the bottom.
http://www.cooknwithgas.com/5_30_06_Engine_Below.JPG
The countersunk holes on top also hold some grease for
lubrication.
I don't have a closeup handy of the top.
I hope this helps,
Scott Laughlin
Omaha, Nebraska
601XL
practice -
David Glass
N253DG reserved
________________________________________________________________________
Gig Giacona
PostPosted: Mon Jul 17, 2006 7:28 am    Post subject: Re: Question about XL lower nose gear support bolts Reply with quote
I just did this last week and while I was doing it I felt like this was the weakest link I've installed in my aircraft to-date.
I like your idea Scott and I may go redo that next weekend. Is there anyway you can get a photo of the top side and post it?
W.R. "Gig" Giacona
601XL Under Construction
nfivesl(at)yahoo.com
PostPosted: Mon Jul 17, 2006 10:11 am    Post subject: Question about XL lower nose gear support bolts Reply with quote
Hi Gig:
I looked through my backup photos and came up with
these two (attached). It's in a tight spot and engine
parts hide most of it these days.
Scott Laughlin
Working on canopy
 Filesize:  161.64 KB
 Viewed:  429 Time(s)
 Filesize:  77.54 KB
 Viewed:  455 Time(s)
