covers
dlm46007(at)cox.net
PostPosted: Thu Jul 13, 2006 6:29 pm    Post subject: covers Reply with quote
In section 35 of the plans, there is a F-1042G-R and -L but below those "wire covers" is  a rectangular area where most of my wiring appears. Does Van's supply or do we just fabricate?
jwt(at)roadmapscoaching.c
PostPosted: Thu Jul 13, 2006 8:02 pm    Post subject: covers Reply with quote
You can order these from Vans. They also come in their wiring kit (which I don't recommend unless you are doing a very basic panel). The wiring kit plans are available separately (to get part numbers from). Tim  O. can give you access to a part of his site with the plans.
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Finish kit - gear legs and wheels
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, July 13, 2006 10:25 PM
Subject: RV10-List: covers
Checked by AVG Release Date: 7/13/2006
dav1111(at)cox.net
PostPosted: Fri Jul 14, 2006 1:51 am    Post subject: covers Reply with quote
I got the wire cover from Van's and was REAL disappointed in it to the point I decided to design my own.  I got built covers to go over the entire side from the front seat up under the panel to the next upright (left and right).  Bent the top over at a 90 degree angle and attached to the top, bottom and front upright with nutplates I installed.  My wife who did the interior covered it and put in map pockets.  As soon as my DAR does my sign off and I button the -10 up for first flight I will take some pictures and post.
Russ
N710RV - Hopefullying first flight within the next few days.
