agustafson(at)chartermi.n Guest
Posted: Fri May 25, 2007 2:50 pm Post subject: Marvel Shebler leak |
I have a carb that even with new needle and seat and new metal float still drips for about 2 or 3 minutes after shutdown. I tried releasing the pump pressure by draining the sump right away but it still drips just as bad. It may be affecting the idle mixture also as it does not shut off the engine at lean cut off. Any help?
Aaron Gustafson
| - The Matronics Continental-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
shoskins(at)mchsi.com Guest
Posted: Sat May 26, 2007 7:14 am Post subject: Marvel Shebler leak |
What is the history of the carb? Is this carb overhauled, or just the needle and seat replaced? Was the work done according to the OH manual? Was the float clearance checked between the pontoons and the bowl?
Was the clearance between the top of the float and the bowl gasket checked?
How about some more info?
Sam Hoskins
Quickie Q-200
Murphysboro, IL
On 5/25/07, Aaron Gustafson < agustafson(at)chartermi.net (agustafson(at)chartermi.net)> wrote:[quote] I have a carb that even with new needle and seat and new metal float still drips for about 2 or 3 minutes after shutdown. I tried releasing the pump pressure by draining the sump right away but it still drips just as bad. It may be affecting the idle mixture also as it does not shut off the engine at lean cut off. Any help?
Aaron Gustafson
[quote][b] http://www.matronics.com/Navigator?Continental-List http://forums.matronics.com
www.MistakeProofing.net/blog/
618-967-0016 ph.
312-212-4086 fax [quote][b]
Posted: Sun May 27, 2007 4:46 am Post subject: Marvel Shebler leak |
Thanks for the replies to this problem. I think I may have it fixed. It was a junk yard carb (Wentworth). I replaced the float (metal) and installed one piece venturi and needle and seat. After taking it apart for the 3rd time and checking all carefully, the bail wire may have been on the opposite side and there was no gasket on the emulsion tube. Yes the needle to float clearance was right and all the bailwire adjustments were correct.
Now I just have a small amount of gas in the bottom of the airbox but no drips. I assume this is OK per reading of others experiences. Does this sound normal? It is on an 0-200.
Aaron Gustafson
Posted: Sun May 27, 2007 6:18 am Post subject: Marvel Shebler leak |
It sounds like it is better, but still not fixed. You may not have enough torque on the seat and you may be getting seepage through the threads. There is a special tool for that and it works much better than trying to do it with a big screwdriver. Were you sure to use the gasket under the seat?
Regarding the gasket on the discharge nozzle (you called it an emulsion tube?), why was it missing? It can be very hard to see, down in the body of the bowl.
For more opinions, you might also consider joining this O-200 Yahoo! group:
http://groups.yahoo.com/group/Q-200_Engine_Group/
Sam Hoskins
On 5/27/07, Aaron Gustafson <agustafson(at)chartermi.net (agustafson(at)chartermi.net)> wrote:[quote] Thanks for the replies to this problem. I think I may have it fixed. It was a junk yard carb (Wentworth). I replaced the float (metal) and installed one piece venturi and needle and seat. After taking it apart for the 3rd time and checking all carefully, the bail wire may have been on the opposite side and there was no gasket on the emulsion tube. Yes the needle to float clearance was right and all the bailwire adjustments were correct.
Aaron Gustafson
618-967-0016 ph.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
