Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Wed Jul 12, 2006 8:19 am Post subject: New F.A.B. alternate air intake |
I installed Van's first version of the alternate air intake, the one with
the magnet holding the door closed. It didn't look like it was going to work
well so when the reports started coming in about them not closing or staying
open, I junked that Filtered Air Box and ordered another one. Then Van's
came out with version 2.0 of the alternate air intake, a round opening in
the bottom of the F.A.B. with a door that pivots on one screw. I installed
that in my new F.A.B. I don't like this one either. My best efforts still
mean it's a one-shot deal. If I open it I will have to remove the lower cowl
to get it completely closed again. Considering that it is an emergency air
source and would only be opened when I thought the front opening was
obstructed, that isn't completely unreasonable.
But I hate the idea of needing to remove the lower cowl anytime anyone pulls
on the control, intentionally or otherwise.
Maybe I am missing something important here. Any thoughts?
Terry
RV-8A finishing
Seattle
klwerner(at)comcast.net Guest
Posted: Wed Jul 12, 2006 8:31 am Post subject: New F.A.B. alternate air intake |
I am not familiar with the layout of version # 2.0, but how about incorporating a spring-load to help to put it back to the shut position?
rocketbob(at)gmail.com Guest
Posted: Wed Jul 12, 2006 9:51 am Post subject: New F.A.B. alternate air intake |
Terry, I did not like version 2.0 either so I scrapped the magnet and the magnet holder of version 1.0, and potted three smaller magnets on the outside of the FAB with 3M DP-190 epoxy. It takes a bit more force to get it open now. I put some dychem machinists ink on the throat of the carburetor as an indicator to show if the door was opening in flight and contacting the carb and so far it hasn't. I absolutely will not put anything mechanical in the path of non-filtered air that could come loose and get sucked into the engine. The airbox really takes a beating from vibration.
Bob Japundza
RV-6 flying, F1 under const.
On 7/12/06, Terry Watson <terry(at)tcwatson.com (terry(at)tcwatson.com) > wrote: | Quote: | --> RV-List message posted by: "Terry Watson" < terry(at)tcwatson.com (terry(at)tcwatson.com)>
Larry Bowen
Posted: Wed Jul 12, 2006 11:40 am Post subject: New F.A.B. alternate air intake |
You can't reach in through the exhaust opening in the lower cowl?
I glassed my version 1.0 door shut; and close the carb heat door/alt air
door at first indication of precip/birds/meteors.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Terry Watson wrote:
work
staying
cowl
pulls
Terry
RV-8A finishing
Seattle
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
lhelming(at)sigecom.net Guest
Posted: Wed Jul 12, 2006 1:19 pm Post subject: New F.A.B. alternate air intake |
Here is my take on the FAB alternate air intake. The FAB was first
introduced without any regard to alternate air intake. Someone, or perhaps
several had a problem with ice on the carb filter as I understand it due to
flying into icing conditions, ie, freezing rain, or snow and the carb heat
activated after the fact did not melt the ice because the warmed air could
not flow to melt the ice. The pop up door remedied this problem but on some
large engines like the 360 it could open due to the amount of vacuum created
during high power settings such as during take off in perhaps dusty
conditions. That could affect engine longevity because unfiltered air was
getting into the engine. So the pop up door was replaced with a manual door
that the pilot had to activate with a pull lever. The carb heat feature can
close off all freezing moisture if activated before the air filter
completely freezes, thereby cutting off all air movement through the filter.
The new manually activated door allows unfiltered air into the carb when
done can get through the filter.
I don't think there is any problem with the FAB without an alternate air
solution IF the carb heat is utilized before the air filter freezes over
solid. So if the pilot recognizes the possibility of snow or freezing rain
situation and pulls carb heat before air flow is totally cut off, there
should not be a reason to activate the new manual alternate air solution as
the heated air from carb heat will melt the ice on the filter.
Based on this understanding, I removed the pop up door to save my engine
from possible harm and glassed over it and did not install the sliding door
solution. Aside from not activating carb heat in time, the one situation
that the manual alternate air system will help on is if a plastic bag, or
bird, or something is ingested in the air input that cuts off air to the
carb. I don't know but the vacuum pressure could be strong enough to burst
a bag and it might not be a problem without the alternate air. I liked the
pop up door before I learned of its weakness. I am surprised Vans did not
just strengthen the door so it could not accidentally deploy. Someone
suggested adding stronger magnets. I think that is a better solution.
Indiana Larry
Terry Watson
Posted: Wed Jul 12, 2006 2:08 pm Post subject: New F.A.B. alternate air intake |
Thanks Indiana Larry. That all makes good sense, but I have fuel injection
and therefore no carb heat door. A carb heat door would solve part of the
problem -- if a bird or big snowball got stuck in the intake ahead of the
carb heat inlet -- but the alternate air door is intended to also let air
into the engine if the filter gets covered with ice, as I understand it. So
a carb heat door, even with a fuel injection system, would solve half of the
problem, or handle some but not all of the anticipated possible air inlet
blockages.
And thanks North Carolina Larry. Because I have a nosewheel, I don't think I
could reach up in there to close the door properly, but I would sure give it
a try before I removed the lower cowl.
I think I can live with what I have, but I am still hoping someone has come
up with an idea that makes this door work as intended. I have been thinking
about getting a control cable with a T-handle and push-button to discourage
me from pulling the wrong knob, but my history warns me that might not stop
me.
Terry
Indiana Larry
bicyclop(at)pacbell.net Guest
Posted: Wed Jul 12, 2006 4:54 pm Post subject: New F.A.B. alternate air intake |
One thing to think about. Many RV's don't have enough temperature rise
with carb heat to do much good. That little tube with the bite out of it
that Van's sells is about useless. Deploying carb heat in a timely
manner in snow might not do enough and you might still wind up with
filter blockage. Even if you have to manually reset it after use,
alternate air might save the day sometime.
Pax,
Ed Holyoke
Tim(at)MyRV10.com Guest
Posted: Wed Jul 12, 2006 5:18 pm Post subject: New F.A.B. alternate air intake |
Terry, I'm flying an RV-10 with the new style FAB door. Also using
F.I. like you are, so I didn't add carb heat or any other options, just
the simple door. If it were me, I'd just leave it as-is. The knob
isn't super easy to pull, and in 90 hours now nobody's touched it.
You could even label it with a warning if you wanted, but considering
that YOU'RE the pilot and will likely be in the plane all the time,
the chance is pretty slim it'll get messed with...and if it does,
how many times do you think it'll happen?? I'd rather remove the
cowl 1 or 2 times over the airplane's lifetime because someone
touched the valve than spend a ton of time trying to change the way
things work. On the -10, I am betting I can reach the FAB from
under the nose anyway.
Terry Watson wrote:
blockages.
me.
Terry
Hopperdhh(at)aol.com Guest
Posted: Wed Jul 12, 2006 5:35 pm Post subject: New F.A.B. alternate air intake |
Terry,
I agree -- its a one shot deal. I couldn't get mine to seal all that well either, so I put a very small bead of RTV around it. Its there only for a rare emergency.
One correction though. You can easily close it with only the upper cowl off.
Dan Hopped
RV-7A 200 HP IO-360
In a message dated 7/12/2006 12:21:02 P.M. Eastern Daylight Time, terry(at)tcwatson.com writes:
Terry
RV-8A finishing
Seattle |
Tim_Lewis(at)msm.umr.edu Guest
Posted: Wed Jul 12, 2006 6:02 pm Post subject: New F.A.B. alternate air intake |
On my RV-6A (following involuntary glider training precipitated by snow
in the FAB) I built a somewhat complicated filter bypass that takes the
carb heat air (not hot enough to melt snow) and dumps it in the FAB
AFTER the air filter. See
<http://home.earthlink.net/~timrv6a/RV6_FAB.jpg>
I like Van's alternate air solutions better than what I built for my
-6A, but Van's wasn't available at the time.
For my RV-10 (IO-540) I'm using a hinged alternate air door on the
bottom of the FAB that opens and closes using the push/pull cable,
rather than the "one way" sliding door arrangement. Photo is at
<http://home.earthlink.net/~timrv6a/Alt_air.jpg>. I've not flown the -10
yet.
Tim Lewis
N47TD
Ed Holyoke wrote:
Pax,
Ed Holyoke
Fred.Stucklen(at)UTCPower Guest
Posted: Thu Jul 13, 2006 9:27 am Post subject: New F.A.B. alternate air intake |
I've done something a little different on my RV-6A. I've tested Van's original magnet scheme and found that my O-320-D1A engine doesn't open it under normal take off conditions. A plugged filter does open it OK. (Don't ask how I know.) The actual implementation of the trap door does not open into the lower cowl, but rather, into the FAB box it self. There's enough space between the bottom of the filter assembly and the FAB box shell to allow for the intake air flow. This way, the carb heat is always available to either filtered or unfiltered air. I periodically check the position/operation of the trap door by inserting a stiff wire through a small hole in the FAB box. And, yes, I epoxied the magnet into position so it can't get detached.....
Fred Stucklen
RV-6A N926RV
720 Hrs 3'd offender
Building an RV-7A
--> RV-List message posted by: Tim Lewis <Tim_Lewis(at)msm.umr.edu (Tim_Lewis(at)msm.umr.edu)>
yet.
Tim Lewis
N47TD
