Posted: Mon Jul 03, 2006 12:38 pm Post subject: Drilling exhaust for EGT |
Fellow listers,
I'm getting ready to drill into my Vetterman exhaust to install the EGT transducers for my VM1000 engine monitor.
I've already got some of the CHT transducers wired and working so I think I have my transducer wiring technique working.
Other than drilling them the same distance down from the head mounting flange and staying away from the spark plugs, I haven't been able to find any info on the best place to drill the holes. Even though straight outboard looks like a great place to put them - I'm wondering about the cowl (I have a Sam James Cowl).
Anyone out there have any photos of what worked well for them?
Kinda scary - drilling holes in an exhaust system...don't they leak?
Ralph Capen
RV6A N822AR (at) N06 Wiring firewall foreward
Posted: Mon Jul 03, 2006 12:51 pm Post subject: Drilling exhaust for EGT |
Fellow listers,
Ralph Capen
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Jul 03, 2006 2:45 pm Post subject: Drilling exhaust for EGT |
Ralph,
I think straight out would interfere with your cowl. Remember too that the
wires won't want to make a sharp 90 degree bend at the end of the
transducer. I feel like I lucked out with mine, not realizing how the lower
plugs were going to protrude. Mine sweep back on the outside, maybe 45
degrees instead of 90 degrees. I think I have seen some turned in somewhat
towards the engine which kept the wires from the transducers more out of the
way.
Hopefully someone else will give you a better answer.
Terry
RV-8A finishing?
Seattle
lhelming(at)sigecom.net Guest
Posted: Mon Jul 03, 2006 3:32 pm Post subject: Drilling exhaust for EGT |
You will not want to drill them at a 90 degree bearing to your longitudinal
plane. Rather, you want to drill them more on a 45 degree angling back
toward the rear of the engine. You can angle them toward the
outside/cowling or the inside. I did mine toward the outside because I
could drill it with the exhaust system installed on the engine. It works
fine. It would however probably be a cleaner install to drill the angle
toward the center of the rear of the engine on about a 45 degree angle but
that would require careful marking and exhaust removal and reinstall unless
you have a nice tight fit angle drill. That inside route would remove any
chance of interference with the cowling. The exhaust system will be tight
with a properly installed sensor and will not leak. Larry in Indiana
FLYaDIVE(at)aol.com Guest
Posted: Mon Jul 03, 2006 5:31 pm Post subject: Drilling exhaust for EGT |
In a message dated 7/3/06 4:44:39 PM Eastern Daylight Time,
recapen(at)earthlink.net writes:
| Quote: | I haven't been able to find any info on the best place to drill the holes.
Ralph Capen
Ralph:
You have to look at EVERYTHING!
What will be blocked - Manifold Nuts & Bolts
Cowling - Well you know that
Where the strap will be when it is fully tightened.
Service loop on the probe wires
NO strain on any of the wires
Distance down from the face of the exhaust flange.
[Remember EGT & CHT are only reference values. Of course CHT is a bit more
accurate as long as you don use Ring or Bayonet Thermocouples. EGT is way too
variable. The numbers you get are YOUR numbers and no one else's. As the
disclaimer goes YMMV.]
I believe all mine are on a 45 Deg angle.
Barry
"Chop'd Liver"
Larry Bowen
Posted: Mon Jul 03, 2006 6:31 pm Post subject: Drilling exhaust for EGT |
Consider orienting the hole so that the wire coming from sensor is pointed
in a friendly direction -- like parrallel to the wire bundle.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Ralph E. Capen wrote:
Fellow listers,
transducers
I have
flange and
the best
great place
Ralph Capen
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Jul 03, 2006 7:30 pm Post subject: Drilling exhaust for EGT |
Not too sure if it matters or not, but I angled mine 45 deg. aft on the right and 45 deg. fwd on the left. My theory is this places the probes in the same relative position on each cylinder (#1 being the exception since the probe is just below the bend on my Vetterman x-over).
FWIW From The PossumWorks in TN
Mark
_________________ From The PossumWorks... |
dreel(at)cox.net Guest
Posted: Tue Jul 04, 2006 6:27 am Post subject: Drilling exhaust for EGT |
Having drilled my O360 A1A's vetterman exhaust both ways, I consider a hole
that helps the wire line up with the lower spark plug leads the best
orientation. The ones I drilled to join the wire bundle that runs along the
crankcase/sump joint are more difficult to work with plus they run through
the hot area just under the cooling fins. Both methods are working OK but I
think bundling with the spark plug leads is a cleaner installation. In my
case, it also let me get all sensors closer to the same distance from the
exhaust port. At the same distance as all the other leads, the number 1
cylinder lead would have angled up to hit the cooling fins.
Also, if you make a mistake, grinding a stainless screw down and securing it
in the hole with a hose clamp is a decent alternative to junking that part
of the exhaust.
Dave Reel - RV8A
