clint_bazzill(at)hotmail. Guest
Posted: Wed Jun 28, 2006 2:15 pm Post subject: Warp drive hub.Very Strange |
My 2 cents worth again. I haven't heard of anyone that disliked there engine or prop.Very Strange world. Clint
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: RE: Warp drive hub.
Date: Tue, 27 Jun 2006 18:02:47 -0700 (PDT)
--> Kitfox-List message posted by: kurt schrader <smokey_bear_40220(at)yahoo.com>
Those are the blades I have John.
Trying to get my mind on topic again to think this in
debth. Not always easy these days.
Wider blades grip air, like all WX tires grip the
pavement. Narrow blades more like dragster tires.
You get a better bite with the wider blades from the
start = more static thrust and less slippage. But the
narrow blades come into their own as you speed up and
allow the engine to spool up better from the start.
The wider ones should run more draggy at higher speeds
and, as was said, for descent and landing.
If your tires grip and not slip, you need a lower
gear. If your prop grips from the start, you use less
pitch to keep RPM's up. Less pitch means the wide
cord blades will run out of pitch sooner in cruise.
Fixed pitch would theoritically like the narrow
blades. But if you have a cockpit adjustable prop,
the wider blades might be better?
Less diameter should mean some more slip too. Less
efficiency on the same pitch and rpm, but maybe allows
more HP from the motor..... You'd need to add a
little pitch for the reduced diameter, so it should be
less static thrust and maybe a slight plus in cruise.
I just canīt see enough gain from reduced diameter to
equate
janderson412(at)hotmail.c Guest
Posted: Wed Jun 28, 2006 9:02 pm Post subject: Warp drive hub.Very Strange |
Lot of drag in these wee aeroplanes eh. I notice at cruise, drop the nose and it'll go easily to 110kts but big struggle to get it to VNE..What streamlining enhancements do you have Kurt? I'm still very much in the learning (FUN) area.
Subject: RE: Warp drive hub.Very Strange
Date: Wed, 28 Jun 2006 15:58:59 -0700 (PDT)
Heck, I was trying to be the resident critic.
Starting at home.... But I accept being strange.
Actually my friendly test pilot noticed it did't feel
like the right prop on the first two 15 minute
flights. He has a IV with the same prop, but non
turbo NSI. His does 110 mph easily. He also tests
other aircraft and has some experience to call on.
I also see it as running into a wall after 100
kerrjohna(at)COMCAST.NET Guest
Posted: Thu Jun 29, 2006 7:28 am Post subject: Warp drive hub.Very Strange |
I will share a friends dislike for his engine combination. Series V 'Fox, with Stratus E81 and IVO Magnum prop (wide chord). With the pitch set to the recommended static rpm, climb out and cruise were nearly the same, ie 85mph. This phenominon was induced by a need to significantly reduce power to avoid over reving in cruise.
After changing to a medium IVO set up he join the ranks of those who are happy.....
John Kerr
From: "Clint Bazzill" <clint_bazzill(at)hotmail.com>
--> Kitfox-List message posted by: "Clint Bazzill"
and , as w uch as
Posted: Thu Jun 29, 2006 8:46 am Post subject: Warp drive hub.Very Strange |
Been wondering about that IVO Magnum myself....
Thanks for the info. It might work as a variable
pitch, but obviously is restrictive as a fixed pitch.
Kinda confirms my theory statement of narrow cords
allowing more latitude thru slippage.
Also wondered how the Stratus works compared to the
NSI. Would be interesting to know the +'s and -'s.
Any other Stratus owners here?
Kurt S. S-5/NSI turbo
--- kerrjohna(at)comcast.net wrote:
| Quote: | I will share a friends dislike for his engine
John Kerr
Posted: Thu Jun 29, 2006 9:27 am Post subject: Warp drive hub.Very Strange |
Well, first keep the fun part going John!
To start with, I built in a fairing to the bottom of
the verticle stab so that the fabric does not make
that hard break to the horizontal stab enclosure. I
also added foam into the gap between the inner ribs of
the horizontal stab and the enclosure sheet metal so
that the gap was zero with full nose up trim and less
a gap for the rest of the travel.
Those were the only drag reductions I built in. Canīt
tell you if they helped much or not, since I have no
comparison. Filling the Horizontal inner gap should
have helped with elevator effectiveness too, but I
don't know for sure.
I added a scoop to the radiator and gained about 9
mph. Less in hot temps with the exhaust door open.
Took it off and added wing strut fairings and gained
an average 10.5 mph. They do not add up to 20 total,
but maybe a 16 mph gain together. I can't remember my
top level speed right now, but it was nice to see.
Still some to go.
Michel and a French friend of his did extensive work
on the wing strut fairing design and it payed off.
Donīt let Michel get away with playing dumb.
Wheel fairings, wing strut end fairings, top and
bottom, gas cap fairings, H. tail strut fairings, jury
strut fairings, other things to go. I'll try to
measure any improvements, if I can, for each.
That makes twice that I had to learn, then relearn not
to float. Releasing that drag made a very noticable
change in the pattern requirements. And if you want
to float lazily along at 65 knots or 75 mph, my Fox is
now a very quiet and fuel efficient plane. But more
to go. It is still working too hard past 85 knots
(100 mph) for me.
Posted: Thu Jun 29, 2006 1:00 pm Post subject: Warp drive hub.Very Strange |
Yep, I did this too, added a profiled leading edge to start of the vert stab
to split the flow. Guess it all helps for as I've said, up to 100kts is
relatively easy. Hopefully after increasing the prop pitch and get the boost
up a bit at lower RPM I might get a wee bit more..John
I
Still some to go.
(100 mph) for me.
Posted: Fri Jun 30, 2006 12:02 pm Post subject: Warp drive hub.Very Strange |
John,
The first 85 knots is easy for me, but the next 15 to
25 is a struggle. I have to check, but I think I top
out around 109 kts now at more than twice the fuel
flow of 85 kts.
I am wondering if my flapperons might be adjusted a
little too low and could use a few degrees up? Other
list members said they make a big difference. I sure
know the first notch makes 70 kts (max flap speed)
almost as draggy as 85 kts clean.
Or it may be my prop, like I said.
Kurt S.
| Quote: | Yep, I did this too, added a profiled leading edge
more..John
Posted: Fri Jun 30, 2006 12:48 pm Post subject: Warp drive hub.Very Strange |
Hmmm, I originally set all my controls up with a spirit level, but then on the final setup used a electronic inclinonmeter(?spelling) and changed the flaperons quite a lot. GPS confirms ASI too. Could be that Kurt. John
Date: Fri, 30 Jun 2006 13:01:58 -0700 (PDT)
John,
flow of 85 kts.
almost as
Posted: Sun Jul 02, 2006 12:50 pm Post subject: Warp drive hub.Very Strange |
I just stuck by the book on mine and the rigging
turned out square on the ground and in flight, just
slow. I used a gravity, not digital inclinometer
(?)to get it right.
I suspect some reflex of the flapperons is called for
and I can do a bit quickly thru the flap linkage. On
the to-do list.
Thanks John,
Kurt S.
that Kurt. John
Posted: Sun Jul 02, 2006 8:52 pm Post subject: Warp drive hub.Very Strange |
I guess Kurt a bit of trial and error in the flaperon area may tell you a
lot...Spoke to my son (my LAME and rigger). Said if it's flying wings level
and both flapperons travel is the same it should be ok. In my early fixed
wing days we had one C185 that was just a 'dog', from day one and nothing on
earth would make it go..someone put it through fence in the end to nobodys
surprise. Not suggesting you wee love machine is in that cat but I was
flying mine this afternoon and just lower the nose in cruise a little an 110
just like that?? And hard to slow it on approach too with the tapered
prop... Be good if you were just down the road, we could compare..John
(?)to get it right.
the to-do list.
Thanks John,
Kurt S.
that Kurt. John
Looking for love? Check out XtraMSN Personals
http://xtramsn.match.com/match/mt.cfm?pg=channel&tcid=200731
kerrjohna(at)comcast.net Guest
Posted: Mon Jul 03, 2006 7:12 am Post subject: Warp drive hub.Very Strange |
Kurt, another place to look is the horizontal stab incidence. With my IV, I had to fly with down trim (drooped flaperons) initially for straight and level. When I left the trim in place and landed I found that they were hanging down 11*. I raised the leading edge of the horizontal about an inch and a quarter (the IV had 2 options on the plans). And now straight and level has the flaperons in perfect trail and the speed increased as expected.
John Kerr
From: "John Anderson" <janderson412(at)hotmail.com>
[quote] --> Kitfox-List message posted by: "John Anderson"
prop... Be good if you we re just down the road, we could compare..John
(?)to get it right.
the to-do list.
Thanks John,
Kurt S.
electronic incl inonme
