RYO Center console - Sharing time
Deems Davis
PostPosted: Thu Jun 29, 2006 3:47 pm    Post subject: RYO Center console - Sharing time Reply with quote
For the past couple of weeks I've been working on a fiberglass center
console, to accompany the panel that I bought from Aerotronics.
Originally I had planned to make my own panel, but when I found the
Aerotronics panel, it was better than what I had planned. however that
left the issue of the console. I was a bit nervous starting out, and yes
the fiberglass itches and the resin is messy, and it turns the
garage/shop into a disaster relief area, but it turned out pretty well
for a rookie. I though I'd post some links it in case others of you were
thinking of doing something similar. (Its sure a lot cheaper than
buying the Lancair parts).
Link to section which details the setps and time
http://deemsrv10.com/upperfwdfuseinstallationlogindex.html
Link to Photo Album, which contains thumbs & pics of all the panel and
console pics.
http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/index.html
Deems Davis # 406
Fuse
acs(at)acspropeller.com.a
PostPosted: Thu Jun 29, 2006 4:14 pm    Post subject: RYO Center console - Sharing time Reply with quote
Deems, this is good stuff!
Maybe a new business for you?
How much to make me one?
John 40315
Rick S.
PostPosted: Thu Jun 29, 2006 6:44 pm    Post subject: RYO Center console - Sharing time Reply with quote
Nice job Deem's!!
How many plys? And how undersized did you make the foam to allow for the layup? Really nice.
I was following your daily progress. Can't you remove the foam with Acetone instead of digging it out?
You should have made a plug then you could make all of us one!! Wink
Rick S.
40185
Rick S.
RV-10
40185
henkjan(at)zme.nl
PostPosted: Thu Jun 29, 2006 10:36 pm    Post subject: RYO Center console - Sharing time Reply with quote
I made a center tunnel also but for the throttle quadrant instead of the
cables, and I do make a mold, what you see is the plug.
http://www.mykitlog.com/users/display_log.php?user=phzme&project=1&categ
ory=1632&log=15194&row=1
Henkjan van der Zouw
#355
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] Namens Deems Davis
Verzonden: vrijdag 30 juni 2006 1:45
Aan: rv10-list(at)matronics.com
Onderwerp: RYO Center console - Sharing time
console pics.
.html
Deems Davis # 406
Fuse
capsteve
PostPosted: Thu Jun 29, 2006 10:39 pm    Post subject: RYO Center console - Sharing time Reply with quote
Boy, that’s a beautiful setup, well done. I looked at lancair iv panels and
cant seem to find that particular one. Where did you find it and how much??
Steve
40205
console pics.
l
Deems Davis # 406
Fuse
