Solder Station & Solder vs Crimp
Michael Wynn
PostPosted: Sun Jan 15, 2006 8:48 am    Post subject: Solder Station & Solder vs Crimp Reply with quote
Hi guys
I took a quick look at Metcals online. Looks like there are quite a number
of models available. What do you recommend? As a sub-question, I wonder if
one is better off crimping connections or soldering. Where do you use which?
I have always thought of soldered joints as more electrically reliable.
However, there is a stiff part where the solder runs up the wire. That would
seem to be more prone to vibrational damage than a properly crimped joint.
Thoughts?
Michael Wynn
RV 8
San Ramon
Michael Wynn
RV 8
San Ramon, CA
mprather(at)spro.net
PostPosted: Sun Jan 15, 2006 10:13 am    Post subject: Solder Station & Solder vs Crimp Reply with quote
The issue of crimp or solder has been discussed at length on this list
in the past. If you are interested, I recommend a perusal of the
archives. The short answer is that either technology can be used
successfully, with few exceptions, as long as it is done in a
craftsmanlike manner. Both technologies require the use of appropriate
strain relief, and physical support against vibrational damage. In
general, if wire leading to a hardpoint (be it a crimped, or soldered
joint, or some other rigid, constraining interface) is allowed to wiggle
around, work hardening of the conductor will take place, and that will
lead to broken wire.
Matt-
MLWynn(at)aol.com wrote:
Hi guys
Thoughts?
Michael Wynn
RV 8
San Ramon
nuckollsr(at)cox.net
PostPosted: Sun Jan 15, 2006 10:33 am    Post subject: Solder Station & Solder vs Crimp Reply with quote
At 11:47 AM 1/15/2006 -0500, you wrote:
Hi guys
Cheap ones. Buy off Ebay . . . See Ebay items:
7579854071
7580532665
7580702004
and others under "metcal" search term
They are for all practical purposes interchangeable
technologies. One is more expensive and less process
sensitive but either can produce long-lived joints.
would
Thoughts?
Much of what's circulated as fact is indeed myth. See:
http://aeroelectric.com/articles/rules/review.html
http://aeroelectric.com/articles/big_term.pdf
http://aeroelectric.com/articles/CrimpTools/crimptools.html
