R-582 issues
akfotoman
PostPosted: Wed Jun 28, 2006 11:28 pm    Post subject: R-582 issues Reply with quote
Does anyone have any information about the exact proper cooling temp for a 582 running an E-gear box with a three bladed prop in the pushing mode? I am constantly running up to 185-190F temps on climb out and cruise. I hear using higher octane fuel, and Dex-cool mixed at 1:1 H20 is the proper combination. Any thoughts?
RS
Have cameras, will travel!
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
fredm(at)cisco.com
PostPosted: Thu Jun 29, 2006 4:36 am    Post subject: R-582 issues Reply with quote
Check the rotax manuals on line I think they say 130-140F.   First think I'd check is the thermostat.
Fred
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Rob Stapleton
Sent: Thursday, June 29, 2006 3:09 AM
Subject: R-582 issues
RS
Malcolmbru(at)aol.com
PostPosted: Thu Jun 29, 2006 6:16 pm    Post subject: R-582 issues Reply with quote
is the thermostat opening properly? is the gage right? can you see a temp drop when the  thermostat opens? 136%it should cycle a couple of times  before  going to 140 or more. has these been happening long? or just started? you should find someone with a similar set up.  how are the egt temps?  good luck  mal
Bob Griffin
PostPosted: Fri Jun 30, 2006 2:35 am    Post subject: R-582 issues Reply with quote
Hi Rob,   When I 1st ran my Kolb mk3 my 618 was running those same temps in climb. I was using the twin radiator set up. As a pusher, the radiator sat behind the eng. and wing , I tried to increase the airflow by removing the intake silencer, then putting scoops on the sides of the rad. Finally, one of Phil Lockwoods techs whispered to me at Sun & Fun, "It's not enough radiator in that configuration".  I went to a local radiator shop and he set me up with a small aluminum and plastic Chrysler radiator for around $100 bucks.  I mounted it in front of the eng and temps were normal from that day on.
Fly Safe
Bob Griffin
Fly Safe
Bob Griffin
Slingerlands, NY
Thom Riddle
PostPosted: Fri Jun 30, 2006 5:05 am    Post subject: R-582 issues Reply with quote
Rob,
The Rotax 2-stroke Installation manual (available at
http://www.kodiakbs.com/tiintro.htm ) says:
.. The radiator must be of adequate size, and the airstream of
sufficeint intensity to maintain the coolant temperature below the
maximum permitted value of 80 degree Celsius or 175 degrees F under the
most sever conditions, i.e., at full load operation (= at take-off).
The average coolant temerature must be 60-80C (140-175F).
In case of pusher propellor installation, take partcular care that
coolant radiator has sufficient air flow.
The max. tmperature difference of the coolant between radiator entry
and exit must not exceed 6C (11F), the average difference must be
around 3 and 5C (5 and 9F).
If the temperature limits are esceeded or coolant flow rate is below
specified values (excessive flow resistance), vapour is produced in the
cylinder head, causing cooling break-down and engine damage.....
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Richard Rabbers
PostPosted: Sat Jul 01, 2006 10:43 am    Post subject: Re: R-582 issues Reply with quote
"It's not enough radiator in that configuration".?
Bob,
I have a 618 though have not yet flown it. I've wondered about the Rotax twin radiator set up which I think may fit inside the cowl of my round cowl model 1 Kitfox. My issues will not be the same as your 'pusher' set up but I'm interested in your Chrysler radiator - please relay the dimentions if it's not too much trouble - Thanks!
Richard / Michigan
