msm_9949(at)yahoo.com Guest
Posted: Wed Jun 28, 2006 10:13 am Post subject: 582 - compression test |
Hello KF listers.
I'm doing my annual condition inspection and one of the items is to check cylinder compression. Is there a recommended technique for the 582 with Ducati CDI? I recall reading that the CDI modules can be fried by cranking the engine with plugs disconnected. Will simply grounding the disconnected plug suffice to prevent damage to modules?
As always, thanks for your assistance.
Marco Menezes
Model 2 582 N99KX
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jun 28, 2006 1:27 pm Post subject: 582 - compression test |
Marco,
With the 912, The recommended technique is to use a differential compression
testor. It has of two dials and you attach the unit in the spark plug hole
and after findind top dead center pressurize to 80 lbs. using the attached
pressure regulator. The unit will then read the pressure in the cylinder -
usually a bit under the 80 lb. reference pressure. In our manual, it gives
the acceptable tolerance.
The only hazard is when the piston is not at TDC. If this is the case, the
piston will be forced down with the pressure and the prop will turn.
Lowell
asq1(at)adelphia.net Guest
Posted: Wed Jun 28, 2006 2:01 pm Post subject: 582 - compression test |
Yes, the prop will turn. VIOLENTLY. Please be careful. Larry
noelloveys(at)yahoo.ca Guest
Posted: Wed Jun 28, 2006 5:27 pm Post subject: 582 - compression test |
Differential testing not only tells you whether or not you have good
compression but will also tell you if you have bad valve seats , which ones
and whether or not you have bad rings.
Set up the diff test and listen for air at the air intake, the exhaust and
the oil filler to tell where the air is escaping.... It is recommended if
you are listening for air to have two people do the test the strongest one
holds the prop at TDC. I can't see why the diff. test wouldn't work on the
two stroke engines to test the integrity of the piston rings.
Noel
[quote] --
bnn(at)nethere.com Guest
Posted: Wed Jun 28, 2006 8:36 pm Post subject: 582 - compression test |
Funny you should ask. I hope I didn't fry my ignition modules, as I just
did a compression test for my DAR sign-off on Friday. I did it the old
fashioned way and came up with 118 psi in each cylinder. As I ran the
engine after I don't think I fried anything, but I didn't do a mag check.
I'll try it tomorrow to make sure.
At 11:12 AM 6/28/2006, you wrote:
| Quote: | I'm doing my annual condition inspection and one of the items is to check
Guy Buchanan
K-IV 1200 / 582-C / Warp / 99.9% done, thanks mostly to Bob Ducar.
smokey_bear_40220(at)yaho Guest
Posted: Thu Jun 29, 2006 8:13 am Post subject: 582 - compression test |
Great summary Noel!
Kurt S.
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | Differential testing not only tells you whether or
not you have good
piston rings.
Noel
skyflyte(at)comcast.net Guest
Posted: Thu Jun 29, 2006 9:03 am Post subject: 582 - compression test |
The differential pressure test is probably not a good idea for a 2 cycle engine. It doesn't take a lot of pressure in the crankcase to blow out the crankshaft seals.
Mike
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: "Noel Loveys"
Noel
> -----Original Mess age--- --
> From: owner-kitfox-list-server(at)matronics.com
> [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of
> Lowell Fitt
> Sent: Wednesday, June 28, 2006 6:53 PM
> To: kitfox-list(at)matronics.com
> Subject: Re: 582 - compression test
> --> Kitfox-List message posted by: "Lowell Fitt"
> Marco,
> spark plug hole
> the attached
> the cylinder -
> usually a bit under the 80 lb. reference pressure. In our [b]> > manual, it gives
> the case, the
> Lowell
Posted: Thu Jun 29, 2006 10:58 am Post subject: 582 - compression test |
My plan was to do an "old fashioned" test. Pull a plug, insert the comp tester, crank the engine a turn or 2 with mags off, read the gauge, repeat on other cyl.. But back to my original question: Does anyone know of I have to take any special precautions to keep from ruining my CDI modules?
Hey Bob Robertson, are you following this thread?
skyflyte(at)comcast.net wrote:
[quote] The differential pressure test is probably not a good idea for a 2 cycle engine. It doesn't take a lot of pressure in the crankcase to blow out the crankshaft seals.
Mike
Noel
> Lowell Fitt
> Marco,
> spark plug hole
> the attached
> the cylinder -
> the case, the
> Lowell
dave(at)cfisher.com Guest
Posted: Thu Jun 29, 2006 12:29 pm Post subject: 582 - compression test |
Marcos,
Good question and I would say that if you know your mags ground out then with both mags off you should have no spark to damage the Ducati igntion.
Dave
rexjan(at)bigpond.com Guest
Posted: Thu Jun 29, 2006 4:37 pm Post subject: 582 - compression test |
I have made about 20 CDI's in my time so I can enlighten you as to what goes on. If you don't have that spark gap when you create a spark you get a very high voltage build up and the solid state components in the modules might well fail. Then again they may not but it's certainly not a good idea to temp fate. When an ignition module fires it builds up voltage until it is high enough to jump the plug gap and then the energy is dissipated. With no plug gap to jump the voltage keeps building to a very high figure. Shorting the plug lead to ground [ the cylinder head or whatever ] will also stop the build up but may overload the module. The right idea is to have the plug lead connected to the plug and the body of the plug grounded. A plug usually fires around 25,000 volts but if the lead is left floating in mid air the voltage may well go to 100,000 with CDI. [ Capacitor Discharge Ignition ]
Rex Shaw.
Posted: Fri Jun 30, 2006 1:27 pm Post subject: 582 - compression test |
The diff test is done with the piston at TDC. Even in a poor cylinder any air passing the compression ring would just leak out the exhaust port without pressurizing the crankcase at all.
Noel [quote]
Posted: Fri Jun 30, 2006 1:42 pm Post subject: 582 - compression test |
Don't bother with the "old fashioned test" There are too many variables. Temperature of the rings... Temperature of the cylinders..... speed the starter can crank the engine. Worst lying SOBs I've ever seen!
Noel [quote]
