Zenith601-List Digest: 0 Msgs - 10/27/14
mvarelasartal(at)yahoo.es
PostPosted: Wed Oct 29, 2014 11:14 pm    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 Reply with quote
Hello alla again,
I need some help as aI have to order parts from aircraft Spruce and I´m in doubt:
- I want to order the throttle control but I don´t quite understand the diferences. I have preselect this one: A-790 Spruce Part Number 05-08160. My engine is a Jabirú and I want both push button lock and fine adjust rotating, Is that one? I´m also planning to mount another one on the other side but Is that posible, Is there a way to unlook it to use fron the right or left side on the cockpit?
- What type of U rubber to seal the canopy on the front? This will fit T-897 Ref. 05-11202
- What type of NACA air inlets for the cabin sides. I´ve preselect 001HE Ref. 05-00862
And the last question and belive me that I don´t want to abuse of all of your patience.... Where can I get the latch system (XL system)? I saw some pictures about how to Weld it to the frame but I don´t know if this kind of latch is sold on a hardware store, Is there an special name for it or reference?
Thanks so much to this fórum in advance. I´m sorry for not attach links and references but Yahoo mail is not so friendly for that. If someone needs for clarify I´ll try to sent from my e-mail.
Marcos
CH601HD (modified)
Spain
El Martes 28 de octubre de 2014 8:11, Zenith601-List Digest Server <zenith601-list(at)matronics.com> escribió:
Today's complete Zenith601-List Digest can also be found in either of the
of the Zenith601-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-10-27&Archive=Zenith601
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-10-27&Archive=Zenith601
  Zenith601-List Digest Archive
  Total Messages Posted Mon 10/27/14: 0
Today's Message Index:
nith601-List" target="_blank">http://www.matronics.com/Navigator?Zenith60bsp; ums.matronics.com/" target="_blank">http://forums.matronics.com/
_; -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
bryanmmartin
PostPosted: Thu Oct 30, 2014 8:28 am    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 Reply with quote
-Throttle cable:
The A-790 does have the fine adjustment feature. I don’t believe the A-790 will work with a two throttle system. The lock on one throttle will prevent the other throttle from moving.
The A-820 will be better for a two throttle system. It has a friction lock that will allow a second throttle to work also.
Both the A-790 and A-820 have a wire end and can be cut to any desired length.
I have only one throttle control in my plane, on the left side of the panel. I have the center Y control stick. I can sit in the right seat and still reach the throttle if I change hands on the stick. I don’t fly from the right seat but I believe the plane could be safely controlled from the right seat in an emergency.
-Rubber seal: The T-897 looks like the same material used by Zenith in the kit. It should work.
-Vents: I have NACA vents like these in my plane. The help keep the cabin cool but on a hot summer day they are not enough. I added a Vista Vent to the each side of the canopy and they work very well. Part # 13-03500 or 05-08078.
Canopy latch: The 601-XL canopy latch is an automotive style door or trunk latch. You might find something usable at a auto parts store or junkyard. Or maybe these would work: http://www.horton.on.ca/Products/prodpages/hoodtrunklatches.htm
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
On Oct 30, 2014, at 2:58 AM, Marcos Varela Sartal <mvarelasartal(at)yahoo.es (mvarelasartal(at)yahoo.es)> wrote:
[quote]Hello alla again,
Marcos
CH601HD (modified)
Spain
Bryan Martin
do not archive.
PostPosted: Thu Oct 30, 2014 12:07 pm    Post subject: Zenith601-List Digest: 0 Msgs - 10/27/14 Reply with quote
Thanks a lot Brian for your answer and tips.....Now are everything clear.
I planning to fly fron the left side (control stick is standard centered) but I prefer to add both controls pedals and throttle to the right side also. I´m flying a Minimax right now but for flight test and so the trainer will fly with me on the first flights....
I also planning to add Vista Vents, these is what I use on the Minimax and Works great. Any way here in the North of Spain it isn´t too hot even in summer.
I´ll find the latchs on a scrapping cars store (I had not thought.....).
Many thanks again......
Marcos
CH601HD (modified)
Spain
El Jueves 30 de octubre de 2014 17:34, Bryan Martin <bryanmmartin(at)comcast.net> escribió:
-Throttle cable:
Bryan Martin
N61BM, CH 601 XL,
Hello alla again,
Marcos
CH601HD (modified)
Spain
http://=======================
