zsmith3rd(at)earthlink.ne Guest
Posted: Tue Jun 27, 2006 4:08 am Post subject: more fuel sender plate/hole |
All previous posts are absolutely correct.
However......if you are not comfortable with trying to enlarge the hole then you can reduce the ring.
Simply clamp it in a vise, saw out about one-quarter-inch of the "notch" in the ring, smooth the cut with a small file, and presto, fits well.
You'll still have to use safety wire, string, magic, luck, etc, to get all the screws in place.
Only problem is the "spacing" of the screws. Mark the sender and the ring so you know which way is north; it'll only fit one way.
Zed
