bakerocb
Posted: Tue Aug 26, 2014 4:33 am Post subject: PC 680 Purchase |
8/26/2014
Hello Fellow Listers, Please tell me (and other readers) why I should pay more for an Odyssey PC 680 battery for my EAB airplane rather than a less expensive battery that “may� be “just as good�.
http://www.batterymart.com/p-odyssey-pc680-battery.html
OC
ceengland7(at)gmail.com Guest
Posted: Tue Aug 26, 2014 5:04 am Post subject: PC 680 Purchase |
On 8/26/2014 7:32 AM, Owen Baker wrote:
| Quote: | 8/26/2014
Â
Â
Â
Â
OC
Â
| I certainly can't help convince you.
I've been using 'no name' AGM batteries in my homebuilts for almost 20 years. The only thing to watch is that some of the AGM batteries are designed for use in UPS power supplies, electric wheel chairs, etc, and their internal impedance is a bit higher than an Odyssey starting battery. Either look for a 'no name' 18AH *starting* battery for a motorcycle/watercraft, or buy a 22 AH AGM battery (same form factor as the Odyssey) and don't worry about the intended application. The slightly higher AH rating pushes the internal resistance down in the same neighborhood as the Odyssey, meaning it can start an engine just as well (or better) than the Odyssey, and has significantly better energy reserve if you're 'electrically dependent'.
rlborger(at)mac.com Guest
Posted: Tue Aug 26, 2014 5:08 am Post subject: PC 680 Purchase |
OC,
My 2¢…
The phrase “may” be “just as good.” sums it up. I don’t like “may be” anywhere near my EAB aircraft. I’ve piddled with other “may” be “just as good” batteries and ended up replacing them with a PC680 because it is the standard by which all the other “may” be “just as good” batteries are compared. It works as promised every time all the time and I think it is worth paying for. So when my last PC680 reached the end of its service life in July, I ordered another PC680 to replace it.
I just wish that battery mart special had been on then. That’s a good deal!
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Aug 26, 2014, at 6:32 AM, Owen Baker <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 8/26/2014
Hello Fellow Listers, Please tell me (and other readers) why I should pay more for an Odyssey PC 680 battery for my EAB airplane rather than a less expensive battery that “may” be “just as good”.
OC
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
"May" be just as good? If you know it just as good there is no reason to pay more for the PC 680 but you seem to have some doubt and that "may" be your answer.
Bob Reed
On Aug 26, 2014, at 7:32 AM, "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)> wrote:
[quote] 8/26/2014
OC
lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
//forums.matronics.com
Posted: Tue Aug 26, 2014 5:14 am Post subject: PC 680 Purchase |
Charlie,
More info on the 22 AH AGM battery
(same form factor as the Odyssey) please!
Brand, cost, source.....
tshankland(at)sbcglobal.n Guest
Posted: Tue Aug 26, 2014 6:34 am Post subject: PC 680 Purchase |
I may be the exception since I am flying an all electric Stratus Suburu, but I have been using a pair of UPS batteries I buy from Batteries Plus for years. I replaced the ones I was using for final building and testing in 2006 but have been using them in a battery pack for remote use ever since and they still work great. I use two 7 AH batteries that are connected in parallel for starting and then run two independent busses for operation. I don't know about starting some of those large bore engines but my Suburu spins and starts fine. I still replace the batteries every couple of years "just in case" at $40.00 each it is cheap insurance, and I have a lot of small 12V batteries for other projects.
Tim Shankland
[quote] ----- Orignal Message -----
Sent: Tuesday, August 26, 2014 8:32 AM
Subject: PC 680 Purchase
8/26/2014
OC
| [b]
deej(at)deej.net Guest
Posted: Tue Aug 26, 2014 7:00 am Post subject: PC 680 Purchase |
On 08/26/2014 08:32 AM, Owen Baker wrote:
| Quote: | 8/26/2014
OC
Hi OC,
I posted this a couple of weeks ago, but will repeat it below. I just
received my new PC680 a couple of days ago and have not installed it in
the aircraft yet, but so far no voltage drop from just sitting on the
bench, unlike the UB12220 battery.
If you get a "good" UB12220 it "may" work fine, but I didn't want to
take a chance on getting stranded somewhere to save $60 in up-front
costs. I was going to replace the UB12220 every year, and have decided
to go for two years with the PC680 based on others' experiences, so the
cost turns out to be about the same in the end.
Here is my previous message:
Listers may recall that I tried one of the UB12220 batteries earlier
this summer:
http://www.amazon.com/gp/product/B001G8FY38/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
I received the battery, put it on the Schumacher charger to ensure it
was fully charged (verified with a voltmeter when done), and installed
in the aircraft (O-320). Cranked over well on the first try and seemed
to turn the engine just as well as the "aircraft" battery that I had
removed.
However, two days later I took the airplane out again, and the blade
turned about 1/3 of the way through a revolution and stopped. Battery
was dead. I have no parasitic loads in my aircraft, so when the master
is off, there is nothing else connected to the battery, and I did not
accidentally leave the master switch on. Pulled the battery, put it on
the charger and let it fully charge (verified with a voltmeter). Left
it on the bench unconnected for a couple of days, and the voltage had
dropped to 10.86 volts.
I am assuming that the battery arrived defective, and I've double
checked the voltage output on the charger I used. This is only one data
point, but I will likely go with the PC680 when I get around to ordering
another battery.
On the positive side the company gave me a full refund on the battery,
so the overall "cost" was my time in trying the experiment.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Posted: Tue Aug 26, 2014 8:56 am Post subject: PC 680 Purchase |
On 8/26/2014 10:00 AM, Dj Merrill wrote:
> 8/26/2014
> Thanks,
> OC
Hi OC,
this summer:
removed.
another battery.
-Dj
DJ,
I'd never tell you to do something you're not comfortable with, but I *would* caution against implying that a single event makes a universal principle. Remember, others have documented DOA & early failures of Odyssey batteries, too.
I've used 'cheap' batteries in my plane for almost 20 years, and the only early failure I've had was due to a pinhole in a case; obviously a handling or or shipping issue. Even in that 'case' (pardon the pun), the battery's starting ability slowly degenerated over several months. Due to family and general 'life' issues, I sometimes go a month or more between flights, and my multi-year old cheapie still cranks my O320 just fine. Therefore, no evidence that 'the UB12220' self-discharges any faster (or slower) than a PC680. I haven't bothered with capacity testing yet, because this plane is a day-vfr, non-electrically dependent a/c. I promise that I'll pay more attention to battery condition (but I'll still use a cheapie) when my electrically dependent -7 flies.
Posted: Tue Aug 26, 2014 9:22 am Post subject: PC 680 Purchase |
How about TESTING what ever brand of battery you use? The interesting thing about this thread is what is NOT said. Whether the writer is for or against any particular battery, the criteria for battery selection is accompanied by little if any DATA.
I've lurked the aviation forum battery threads for decades. I'm saddened to report than in no instance has anyone advocated for any particular battery based on measurements and assessment of data and operating conditions that offer a reader opportunity to repeat the experiment.
I've yet to read about any battery getting replaced for failure to meet battery-only endurance requirements. They get replaced when cranking performance degrades or fails.
Batteries not withstanding, suitability to task for any commodity is subject to a huge array of variables. We are never privy to the operating conditions or life-time experiences of batteries that performed well versus those that have received poor marks.
Did a short-lived battery experience a deep-discharge event? Is the charging voltage appropriate to long life. How many cranking events did the Brand A successfully power vs. those for Brand B? What was the cost-of-ownership for Brand-A vs. Brand B?
I do not suggest that anecdotal data has no value but it's a good thing that we understand the difference between suds-n-burgers data versus engineering data. The next time somebody offers service life data on a battery, it would be REALLY cool if the writer could offer months in service where an endurance goal of x.x hours at x.x amps was supported. If you've got an endurance bus, then this number is easy to get . . . just do a practice session for an alternator out event. During a long cross country, shut the alternator of and time the battery only endurance down to 11.0 volts.
Lacking hard data, the builder faced with a purchasing decision is pretty much on his own irrespective of the S-n-B data offered on the forums. Being willing and able to put NUMBERS on any battery experience is a really good thing.
Bob . . . [quote][b]
Posted: Tue Aug 26, 2014 9:51 am Post subject: PC 680 Purchase |
On 08/26/2014 12:57 PM, Charlie England wrote:
| Quote: | > I am assuming that the battery arrived defective, and I've double
> another battery.
DJ,
principle.
Hi Charlie,
I did point out in my post that this was only one data point, and I was
not trying to make (and hope that no one thought I was implying) that my
experience was a general rule. I tried the "cheap" battery as an
experiment, and determined I didn't want to spend any more effort on it
after the first failure. I freely admit to simply being frustrated and
"just want something that works". On the flip side, I have had great
success with the UB types of batteries in UPS units for years, which is
what prompted me to try it in the first place.
Once bitten, twice shy, as they say...
-Dj
Posted: Tue Aug 26, 2014 10:03 am Post subject: PC 680 Purchase |
On 08/26/2014 01:20 PM, Robert L. Nuckolls, III wrote:
| Quote: | *How about TESTING what ever brand of battery you *
*use? The interesting thing about this thread is *
*what is NOT said. Whether the writer is for or against *
*any particular battery, the criteria for battery *
*selection is accompanied by little if any DATA.*
Hi Bob,
We did discuss this here on the list back in the Spring, along with
criteria for battery selection, data, testing, etc...
Not sure there is any point in rehashing the entire thread since it is
available in the archives, but the gist was simply to try it and see
what happened. I did, I wasn't satisfied, and decided as my fallback to
go with the more main stream solution, the PC680. Personally I don't
care what is stamped on the side of the battery as long as it works,
hence my willingness to attempt the experiment with the "cheap" battery.
It is possible that if I bought a second UB-type battery that it would
work fine, or possible that it would not, and I simply want to get the
plane back flying without having to fuss with it anymore. I "feel"
(nothing quantitative here) that going with the PC680 offers a higher
chance of success in this regard, given others experience with it.
-Dj
ftyoder(at)yoderbuilt.com Guest
Posted: Tue Aug 26, 2014 2:58 pm Post subject: PC 680 Purchase |
Hi OC, Price Gill or Concord and the PC 680 is Cheap
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Owen Baker
Sent: Tuesday, August 26, 2014 5:33 AM
8/26/2014
OC
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
