GeoB
Posted: Sat Aug 23, 2014 12:52 am Post subject: Kolb-List Digest: 10 Msgs - 08/21/14 |
The only cap I know about that needs to be hooked up with correct polarity
is the electrolytic cap. They have an indentation, like a waist, or band,
near one end. Another thing to be aware of with these is that they 'age'.
They 'dry up' as they have a semi-liquid chemical inside. When I have an old
piece of equipment that goes belly-up I look for obvious things... burned
components, loose solder joints, and then I check the function of the
electrolytic caps. Problem is you have to take them loose at one end to
test, ie take them out of the circuit.
When using recycled parts I'd be sure to test these good, or maybe skip
using old ones. To me they are just trouble waiting to happen.
| Quote: | Another devise that can help is an inductor...
An inductor and capacitor work well together for filtering.
| Quote: | 1 FARAD" capacitors. These held power in reserve
I seriously doubt that you would see benefit for these in our type of
low-current use.
| Quote: | Different application there, the huge cap you used was to provide more
curre
nt for the Bass in your stereo, like a hydraulic accumulator. Here caps are
u
sed to short noise spikes to ground to clean up our 12 volt dc
Yes! What I was trying to say.
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
