JAPhillipsGA(at)aol.com Guest
Posted: Tue Jun 27, 2006 5:35 pm Post subject: Fuel Sender Impossible |
Folks, you that want to cut out and make a bubble in your wing for the sender unit consider this, if you modify the tall center bolt and nut by grinding, that reduces the profile. Second, when you fill the tank the weight of it will settle the tank in the cork you put on the bottom and reduce the profile even more so that the skin clears the top with some to spare. At least that was the way mine went. FWIW, best regards, Bill of Georgia
601zv(at)ritternet.com Guest
Posted: Tue Jun 27, 2006 6:32 pm Post subject: Fuel Sender Impossible |
That may by fine for all you folls that have senders with center bolts, but all us folks that have the ZAC supplied tanks and ZAC supplied VW Rabbit type sendes are still stuck with a protrusion that is substantially more than the thickness of the cork whether the cork is compressed or not.
