bnn(at)nethere.com Guest
Posted: Mon Jun 26, 2006 4:31 pm Post subject: 582 Warp Prop Diameter |
Hi guys,
I was just putting my paperwork together for the DAR, when I
discovered that I have a 70" 3 blade Warp prop. Skystar recommended a 68"
prop for the 582. (I've got a 582 with a 3:1 C box and APC clutch.) I've
got an email into Warp to see if I can cut an inch off, but I'm wondering
if the 70" is better from a performance standpoint. I've checked the tip
speed and it's quite slow. (591 fps, .53 mach at 85 knots and 5800 rpm.)
My other problem is I require documentation proving the combo is
acceptable. How about it John? Do you have any documentation for
K-IV/582/70" Warp 3-blade combinations?
Guy Buchanan
K-IV 1200 / 582-C / Warp / 99.9% done, thanks mostly to Bob Ducar.
dosmythe(at)cox.net Guest
Posted: Tue Jun 27, 2006 8:24 am Post subject: 582 Warp Prop Diameter |
Guy,
I had the 70" Warp with my 582 which was recommended by Warp. A couple years ago I had a small prop strike and sent the prop back to Warp where they cut off 1" to make it a 68". I did not see any noticeable performance difference between the 70" and 68"
Don Smythe
---- Guy Buchanan <bnn(at)nethere.com> wrote:
Hi guys,
Guy Buchanan
