nickc(at)mtaonline.net Guest
Posted: Sat Aug 16, 2014 7:38 am Post subject: ELSA...? |
Hello All,
In my case I bought a kit to recreate a prototype aircraft that no longer exists. It will not be an exact copy of the prototype plane that no longer exists, and the design was and will remain significantly deferent from the production model. Do you think I will be able to get an ELSA?
Nick Cassara
Palmer, Alaska
byoungplumbing(at)gmail.c Guest
Posted: Sat Aug 16, 2014 9:29 am Post subject: ELSA...? |
If the kit was an approved as an esla kit you should be ok. Even if the prototype no longer exist. The inspector will only be able to compare your finished project to the esla approved plans. If you don't have esla plans. Imho in my humble opinion,, your only option is eab. And if you have esla plans and have made any modifications while building your plane does not fit esla rules. You would be left with eab
Boyd young On Aug 16, 2014 9:40 AM, "Nick Cassara" <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:[quote]
Hello All,
Nick Cassara
Palmer, Alaska
tp://forums.matronics.com
rickofudall
Posted: Sun Aug 17, 2014 1:43 pm Post subject: ELSA...? |
Nick, Here are the applicable FAR's on Light Sport Aircraft. For your
Kolbra, Kolb would have to build a qualifying aircraft per the ASTM
standard, document that it meets the standard, and get the FAA to certify
their production and supply system. The manufacturer would then sell you a
kit EXACTLY like their prototype. If you were to make ANY changes to the
kit, the manufacturer would have to issue a letter of authorization (LOA)
for EACH change. Part of the kit package would be a certificate of
conformity that would be presented to the FAA or the DAR, along with any
LOA's at the time your aircraft is presented for inspection for the
experimental certificate, mistakenly called the airworthiness certificate
by most people.
So, the simple answer is that for you to get an ELSA designation, Kolb
would have to have built an SLSA prototype of the Kolbra.
Rick Girard
21.190 Issue of a special airworthiness certificate for a light-sport
category aircraft.
(a) Purpose. The FAA issues a special airworthiness certificate in the
light-sport category to operate a light-sport aircraft, other than a
gyroplane.
(b) Eligibility. To be eligible for a special airworthiness certificate in
the light-sport category:
(1) An applicant must provide the FAA with—
(i) The aircraft's operating instructions;
(ii) The aircraft's maintenance and inspection procedures;
(iii) The manufacturer's statement of compliance as described in paragraph
(c) of this section; and
(iv) The aircraft's flight training supplement.
(2) The aircraft must not have been previously issued a standard, primary,
restricted, limited, or provisional airworthiness certificate, or an
equivalent airworthiness certificate issued by a foreign civil aviation
authority.
(3) The aircraft must be inspected by the FAA and found to be in a
condition for safe operation.
(c) Manufacturer's statement of compliance for light-sport category
aircraft. The manufacturer's statement of compliance required in paragraph
(b)(1)(iii) of this section must—
(1) Identify the aircraft by make and model, serial number, class, date of
manufacture, and consensus standard used;
(2) State that the aircraft meets the provisions of the identified
consensus standard;
(3) State that the aircraft conforms to the manufacturer's design data,
using the manufacturer's quality assurance system that meets the identified
consensus standard;
(4) State that the manufacturer will make available to any interested
person the following documents that meet the identified consensus standard:
(i) The aircraft's operating instructions.
(ii) The aircraft's maintenance and inspection procedures.
(iii) The aircraft's flight training supplement.
(5) State that the manufacturer will monitor and correct safety-of-flight
issues through the issuance of safety directives and a continued
airworthiness system that meets the identified consensus standard;
(6) State that at the request of the FAA, the manufacturer will provide
unrestricted access to its facilities; and
(7) State that the manufacturer, in accordance with a production acceptance
test procedure that meets an applicable consensus standard has—
(i) Ground and flight tested the aircraft;
(ii) Found the aircraft performance acceptable; and
(iii) Determined that the aircraft is in a condition for safe operation.
(d) Light-sport aircraft manufactured outside the United States. For
aircraft manufactured outside of the United States to be eligible for a
special airworthiness certificate in the light-sport category, an applicant
must meet the requirements of paragraph (b) of this section and provide to
the FAA evidence that—
(1) The aircraft was manufactured in a country with which the United States
has a Bilateral Airworthiness Agreement concerning airplanes or Bilateral
Aviation Safety Agreement with associated Implementation Procedures for
Airworthiness concerning airplanes, or an equivalent airworthiness
agreement; and
(2) The aircraft is eligible for an airworthiness certificate, flight
authorization, or other similar certification in its country of manufacture
