kitfoxplane(at)gmail.com Guest
Posted: Tue Sep 02, 2014 11:00 am Post subject: Trim Motor Adjustment |
I have a series 5 that I can't adjust the trim on. After I do what the manual says and get the 7/16 inch clearance, I run the horizontal all the way down as the manual says. When I run it up it goes all the way and there is no clearance. Any ideas on what is wrong?
When it hits the stop it runs as long as the rocker switch is held. I can't imagine ever running the horizontal that high. Should I just leave it as is? Thanks Jim
kitfoxplane(at)gmail.com (kitfoxplane(at)gmail.com)
