RotaxEngines-List Digest: 1 Msgs - 07/26/14
stan_tew(at)yahoo.com
PostPosted: Sun Jul 27, 2014 10:46 am    Post subject: RotaxEngines-List Digest: 1 Msgs - 07/26/14 Reply with quote
I flew for over 10 years with oil injection. I just filled the reservoir at the beginning of each flight. Do this especially if you are planning a long trip with couple of fuel stops. Also, take a bottle with you. It is small, lightweight and has NO substitute.
STAN 2
On Sunday, July 27, 2014 2:14 AM, RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com> wrote:
Today's complete RotaxEngines-List Digest can also be found in either of the
of the RotaxEngines-List Digest and can be viewed with a generic text editor
HTML Version:
  http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2014-07-26&Archive=RotaxEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2014-07-26&Archive=RotaxEngines
  RotaxEngines-List Digest Archive
  Total Messages Posted Sat 07/26/14: 1
Today's Message Index:
1. 07:48 AM - Oil Usage with Oil Injectin?  (Thumper)
________________________________ Message 1 _____________________________________
Time: 07:48:10 AM PST US
Subject: Oil Usage with Oil Injectin?
From: "Thumper" <dlong1957(at)yahoo.com (dlong1957(at)yahoo.com)>
Roger or others.
With a 582, one take off and one landing, cruising at 5800 rpm what should
the oil usage be? Should it use the equivalent of 50-1 (12 gallons of gas used
and 32 ounces of oil) or will be it somewhat less. At idle the mark on the
oil pump lever is slightly advanced from the mark on the pump which indicates
it should be using more oil than normal? Is the same lever used on all engines?
Seems like each displacement engine should use different amount of oil since
they all use different amounts of fuel per throttle opening?  Just trying
to know what is right since this is the first Rotax I have used with oil injection.
Dennis
Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
700+hours since 1/1/2009
http://forums.matrRotaxEngines-List" target="_blank">http://www.matronics.com/Navigator?Rotsp; - MATRONICS WEB FORUMS -
