Ernie
Posted: Fri Aug 15, 2014 7:48 am Post subject: Gill Shutter Binding |
What can cause the gill shutter ring on a CJ to bind? Mine requires a lot of effort to actuate. Before I start taking things apart I was hoping there was an obvious answer. It's not the cable, I disconnected it at the actuating arm, and I had to use channel locks to open and close the ring.
Ernie
Ernie
Posted: Fri Aug 15, 2014 9:09 am Post subject: Gill Shutter Binding |
Thanks Doug,
Each wobbler seems to be held in place with a small slotted screw which is safety wired to its neighbor. Can they be over tightened?
Ernie
On Fri, Aug 15, 2014 at 1:01 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
[quote]Ernie,On the bottom of each gill/vane there is a small steel 90 degree "arm" the correct name is a wobbler. The wobbler should have a smooth slot in it. If the wobblers have been vibrating on the hardware they will have developed a notch in the slot. The gills are most likely hanging up in this notch. Another problem may be that the center ring holes are all wallowed out, this will also cause the gills to bind up.
Check book #2 of the IPBs for the dwg/breakdown of the shutter system.
I carry all the various shutter parts in stock.
Hope this helps.
Doug
On Fri, Aug 15, 2014 at 8:46 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | What can cause the gill shutter ring on a CJ to bind? Mine requires a lot of effort to actuate. Before I start taking things apart I was hoping there was an obvious answer. It's not the cable, I disconnected it at the actuating arm, and I had to use channel locks to open and close the ring.
Ernie
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
| [b]
dougsappllc(at)gmail.com Guest
Posted: Fri Aug 15, 2014 9:17 am Post subject: Gill Shutter Binding |
No, it would be pretty hard to over tighten them, no need to go more than snug as they are safety wired. Depending on how old they are they may be worn and binding also.
On Fri, Aug 15, 2014 at 10:09 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote] Thanks Doug,
Ernie
| Quote: | Ernie,On the bottom of each gill/vane there is a small steel 90 degree "arm" the correct name is a wobbler. The wobbler should have a smooth slot in it. If the wobblers have been vibrating on the hardware they will have developed a notch in the slot. The gills are most likely hanging up in this notch. Another problem may be that the center ring holes are all wallowed out, this will also cause the gills to bind up.
Hope this helps.
Doug
cjpilot710(at)aol.com Guest
Posted: Sat Aug 16, 2014 5:15 am Post subject: Gill Shutter Binding |
All who read - heed.
Doug & Katherine,
Please forget the panic and mournful call for help yesterday. It was the result of fatigue, memory loss and being rushed. Fatigue from just driving straight to Tulsa from Fla. and back in 3 days. Memory loss - part fatigue and not remembering where I put the engine mount bolts AND they are different sizes (short ones on top and long ones on bottom). And rushed - my brother could only spend a few days with me to help.
I am partly squared away at this point, (still trying to get my 2nd medical out of the way). Have no need now of engine mount bolts.
Jim "Pappy" Goolsby
In a message dated 8/15/2014 1:17:22 P.M. Eastern Daylight Time, dougsappllc(at)gmail.com writes:
| Quote: | No, it would be pretty hard to over tighten them, no need to go more than snug as they are safety wired. Depending on how old they are they may be worn and binding also.
| Quote: | Thanks Doug,
Ernie
| Quote: | Ernie, On the bottom of each gill/vane there is a small steel 90 degree "arm" the correct name is a wobbler. The wobbler should have a smooth slot in it. If the wobblers have been vibrating on the hardware they will have developed a notch in the slot. The gills are most likely hanging up in this notch. Another problem may be that the center ring holes are all wallowed out, this will also cause the gills to bind up.
Hope this helps.
Doug
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Ernie
Posted: Sun Aug 17, 2014 7:31 am Post subject: Gill Shutter Binding |
Thanks all,
All that was needed was a little LPS-3 on the wobblers. Works like a champ now.
Ernie
On Fri, Aug 15, 2014 at 1:15 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
[quote]No, it would be pretty hard to over tighten them, no need to go more than snug as they are safety wired. Depending on how old they are they may be worn and binding also.
Ernie
Hope this helps.
Doug
