jdriggs49(at)msn.com Guest
Posted: Wed Jul 16, 2014 11:57 am Post subject: Rusty RV-8 Steel Parts and other problems |
I'll give you my tail of woe!
Last Sunday I was making a routine landing at my home airport and on the rollout the nose gear departed the plane and then the gear strut stuck into the pavement and when the plane continued over it folded up underneath. It was a main gear landing at a slow speed. Prop strike, very badly mangled firewall where the nose gear strut cut into it, big gouge on left side where the nose wheel hit fusalage and then into the left flap. All at low speed. Gas everywhere. I was fortunate that it didn't roll over when the strut dug into the pavement. The insurance adjustor come out today and looked it over. His opinion agreed with me as to cause of accident. The gear strut broke at the weld where it attaches to the upright spindle on the wheel assembly. Looks to be a very poor weld and not a very robust design to boot. The weld was very small in width and didn't penetrate very deep. Split right down the middle of the weld, I wonder how many ticking time bombs are out there ready to blow off the nose gears. Not in a place to check very often either. Dan
| Quote: | Date: Sun, 13 Jul 2014 11:28:20 -0700
Subject: Rusty RV-8 Steel Parts
I sent this email to Van's today. Something to watch out for...
>Date: Sun, 13 Jul 2014 11:23:02 -0700
>To: support(at)vansaircraft.com
>From: Matt Dralle <dralle(at)matronics.com>
>Dear Van's,
>I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off.
>The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default.
>Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above.
>FYI.
>Matt Dralle
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Matt's Livermore Airport Live ATC Stream!
Check out the live ATC stream directly from my hangar at the Livermore
Airport. Includes both Tower and Ground transmissions. Archives too!
For entertainment purposes only. http://klvk.matronics.com
rv10john(at)yahoo.com Guest
Posted: Sat Jul 19, 2014 5:43 am Post subject: Rusty RV-8 Steel Parts and other problems |
Hi Danny,
I would like to examine my nose gear for the poor weld. I am not sure what weld you are talking about. Is a picture available? Thank you for speaking out on this issue.
John Morrow
#40461, airframe complete
On Wednesday, July 16, 2014 4:09 PM, Danny Riggs <jdriggs49(at)msn.com> wrote:
>Dear Van's,
>FYI.
>Matt Dralle
[quote]hthttp://www.matronics.com/contribut==============
Albert Gardner
Posted: Wed Jul 23, 2014 11:22 am Post subject: Rusty RV-8 Steel Parts and other problems |
The RV-10 and RV-8A nose gear leg are different.
Albert Gardner
N991RV
Yuma (hotter than hell) AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Morrow
Sent: Saturday, July 19, 2014 6:38 AM
Subject: Re: Rusty RV-8 Steel Parts and other problems
Hi Danny,
John Morrow
On Wednesday, July 16, 2014 4:09 PM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
From: dralle(at)matronics.com (dralle(at)matronics.com)
>To: support(at)vansaircraft.com (support(at)vansaircraft.com)
>From: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
>Dear Van's,
>FYI.
>Matt Dralle
| Quote: | | [/url][url=http://forums.matronics.com/][/url][url=http://forums.matronics.com/][/url][url=http://forums.matronics.com/] | 01234567890
RV-10 N991RV |
Posted: Wed Jul 23, 2014 11:54 am Post subject: Rusty RV-8 Steel Parts and other problems |
It's where the nose gear leg meets the nose gear assembly.
[img]cid:inlineImage0[/img]
Subject: RE: Rusty RV-8 Steel Parts and other problems
Date: Wed, 23 Jul 2014 12:19:55 -0700
Albert Gardner
N991RV
Hi Danny,
John Morrow
>Dear Van's,
>FYI.
>Matt Dralle
1[/u][/b]
1.78 MB |
4334 Time(s) |
In the pix I posted the wheel is to the left.
Albert Gardner
N991RV
Hi Danny,
John Morrow
>Dear Van's,
>FYI.
>Matt Dralle
1[/u][/b]
Posted: Wed Jul 23, 2014 1:57 pm Post subject: Rusty RV-8 Steel Parts and other problems |
As you can see the weld fillet is VERY small and the weld didn't penetrate very well.
Date: Wed, 23 Jul 2014 14:52:28 -0500
Albert Gardner
N991RV
Hi Danny,
John Morrow
>Dear Van's,
>FYI.
>Matt Dralle
1[/u][/b]
1.78 MB |
4332 Time(s) |
