Jacking up the RV8 using a hole drilled in the U807 wheel pa
vshimsl(at)live.com
PostPosted: Sat Jun 28, 2014 2:42 pm    Post subject: Jacking up the RV8 using a hole drilled in the U807 wheel pa Reply with quote
A couple of years ago, while at Felts Field, another RV8 builder suggested I drill a hole in my U807 wheel pant mounting flange to access the gear leg recess. I could then insert a bolt into the hole and use a bottle jack to lift my wheel to change the tire.
A slick idea I mentally filed away until, of course, I forgot most everything he told me.
If you've tried this idea, I would appreciate the details.
VinceH
RV8432 - Flying
Yes I really should finish the wheel pants
