Baffling Question
rv10free2fly(at)yahoo.com
PostPosted: Sun Jun 22, 2014 2:47 am    Post subject: Baffling Question Reply with quote
I am trying to fit the CB-1001A Front Baffle (Ref. Page FF2-14) which as shown on the plans, should fit snugly over and around the MT P-420-3 propeller governor.
Vans sent me the MT P-860-3 propeller governor with my Firewall Forward kit, which is now installed on my engine. This governor has a lip around the front which prevents the CB-1001A Front Baffle from slipping over the governor.
I am tempted to cut the hole in the CB-1001A Front Baffle much larger, however this will then mean that I will need to seal around the opening in the CB-1001A, as once the baffle is over the front of the governor, the body of the governor reduces in diameter, leaving about a 1/4" gap around the governor to the edge of the hole in the CB-1001A.
Have I buggered up my interpretations of the plan, or does the new propeller governor just not fit the CB-1001A baffle as was originally intended?
If so, what are people using to seal the gap between the propeller governor and the CB-1001A.
After mucking around with these baffles, I can now see why people install plenums in lieu of baffles!
I'd appreciate your assistance and any links or photos that could assist me please.
Warm regards and thanks in anticipation.
Patrick Pulis
Adelaide, South Australia
#40299
jesse(at)saintaviation.co
PostPosted: Sun Jun 22, 2014 4:02 am    Post subject: Baffling Question Reply with quote
That part is always hard to fit. You can trim it as necessary and then seal it (RTV works well). You could also use baffle seal to fill the gap.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Jun 22, 2014, at 6:47 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Patrick Pulis
#40299
flying-nut(at)cfl.rr.com
PostPosted: Sun Jun 22, 2014 4:12 am    Post subject: Baffling Question Reply with quote
I think you've got it right!
I haven't done it yet but I'm planning on a combination of fiberglass
sheet and the cowl seal material.
I'm going to install a plenum .... I hate cowl seal. I also want to
convert the inlets to round ones. The reason I haven't done that
already is I'm on the fence with making my own or going the Sam James route.
Linn ..... just riveted on the fwd upper fuselage!!!
Patrick Pulis
#40299
Checked by AVG - www.avg.com
PostPosted: Sun Jun 22, 2014 4:29 am    Post subject: Baffling Question Reply with quote
Thanks Linn
Warm regards
Patrick
I haven't done it yet but I'm planning on a combination of fiberglass sheet and the cowl seal material.
I'm going to install a plenum .... I hate cowl seal. I also want to convert the inlets to round ones. The reason I haven't done that already is I'm on the fence with making my own or going the Sam James route.
> Patrick Pulis
> #40299
> No virus found in this message.
Kellym
PostPosted: Sun Jun 22, 2014 4:46 am    Post subject: Baffling Question Reply with quote
If you are on the fence, there is one more alternative that may be
better than Sam James: Showplanes RV-10 cowling....
http://tinyurl.com/ojlo6f5
No personal knowledge, just know it exists.
Kelly McMullen
KCHD
PostPosted: Sun Jun 22, 2014 5:48 am    Post subject: Baffling Question Reply with quote
Thanks Kelly. Always good to have a couple of approaches. I already have the Van's cowl fitted and just can't justify pitching it. I'm enjoying the 'journey' and doing some mods to improve (I hope) the Van's approach.
I didn't like Van's alt air ...... I know, you can reset it after shutdown .... so I did this:
[img]cid:part1.08020702.04030205(at)cfl.rr.com[/img]
Because I can ......
I'd probably be flying by now if it wasn't for all the mods Razz
Linn
On 6/22/2014 8:45 AM, Kelly McMullen wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
If you are on the fence, there is one more alternative that may be better than Sam James: Showplanes RV-10 cowling....
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com> (flying-nut(at)cfl.rr.com) .... I hate cowl seal. I also want to convert the inlets to round ones. The reason I haven't done that already is I'm on the fence with making my own or going the Sam James route.
06/21/14
 Filesize:  97.55 KB
 Viewed:  8686 Time(s)
woxofswa
PostPosted: Sun Jun 22, 2014 6:41 am    Post subject: Re: Baffling Question Reply with quote
I put a small piece of piano hinge on the back face of that baffle piece. That allowed me to have a nice tight fitting around the governor and be able to open the hole around the governor via the hinge to get it in and out easier.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Jackm
PostPosted: Sun Jun 22, 2014 8:13 am    Post subject: Re: Baffling Question Reply with quote
Patrick.
Send email to jackm(at)vinetechequipment.com . I will reply with pictures of what we did. Prop cable is also routed above engine and left heat input is on rear right baffle. Prop cable above allows for better seal because you don't need to cut ramp for prop lever clearance
Jackm
