slook(at)mchsi.com Guest
Posted: Fri May 30, 2014 5:17 am Post subject: Cable Rigging? |
I'm ready to rivet the rest of my fuse and baggage floor. Will it be
too much trouble to run the control cables after I do that?
Steve
Steve Look
Monticello, IL
www.ilrt66.com
"Dogs have owners, Cats have staff"
johnd
Posted: Fri May 30, 2014 5:41 am Post subject: Cable Rigging? |
Hi Steve,
Not a problem, you'll have access to run the cables thru the hatch on
the bottom of the fuselage.
John
N601JD
601XL-B
On Fri, May 30, 2014 at 9:17 AM, Steve Look <slook(at)mchsi.com> wrote:
I'm ready to rivet the rest of my fuse and baggage floor. Will it be too
Steve
Steve Look
Monticello, IL
www.ilrt66.com
flyboy3847(at)onecommail. Guest
Posted: Fri May 30, 2014 6:19 am Post subject: Cable Rigging? |
yes
psm(at)att.net Guest
Posted: Fri May 30, 2014 8:31 am Post subject: Cable Rigging? |
Hi Steve,
I don't think you need to worry about running control cables after you
finish assembly of your Zodiac. The only tricky part is getting the
aileron cables into the wings. This can be done easily by tying some
string to the aileron belcrank before finishing the wing and running it
to the inside edge of the wing. Then you can just pull the string with
the cable attached later. If that isn't possible you can push the cable
or a string from the open end of the wing by taping it to the end of a
long wood stick.
Paul
Camas, WA
Zodiac XL in phase II
On 5/30/2014 6:17 AM, Steve Look wrote:
Steve
Steve Look
Monticello, IL
www.ilrt66.com
gpjann1(at)comcast.net Guest
Posted: Fri May 30, 2014 10:37 am Post subject: Cable Rigging? |
Innstalling the cables
Aileron cables can be installed anytime, and the tail cables should be installed before installing top of fuse.
The tensioning of the cables should be done asap.
GPJ
To: "zenith601-list" <zenith601-list(at)matronics.com>
Sent: Friday, May 30, 2014 9:17:25 AM
Subject: Cable Rigging?
--> Zenith601-List message posted by: Steve Look <slook(at)mchsi.com>
Steve
Steve Look
Monticello, IL
www.ilrt66.com
- List Contribution Web Site -
pavel569
Posted: Fri May 30, 2014 10:53 am Post subject: Re: Cable Rigging? |
No problem to install the cables after the fuselage is finished as long as you fit through the fuse bottom opening
_________________ Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive" |
jaybannist(at)cs.com Guest
Posted: Fri May 30, 2014 3:34 pm Post subject: Cable Rigging? |
Steve,
Sure, you can always run cables later. But why not do it the easy way, when access is easy. I ran all my cables as soon as possible and avoided the access hassles later.
Jay
bryanmmartin
Posted: Sat May 31, 2014 6:11 am Post subject: Cable Rigging? |
You might want to run some string where the cables will be run. You can then use the string to pull in the cables later.
On May 30, 2014, at 9:17 AM, Steve Look <slook(at)mchsi.com> wrote:
I'm ready to rivet the rest of my fuse and baggage floor. Will it be too much trouble to run the control cables after I do that?
Steve
_________________ --
Bryan Martin
do not archive. |
