Garage door potentially too low
bob88
PostPosted: Sat Jun 07, 2014 10:11 pm    Post subject: Garage door potentially too low Reply with quote
Has anyone successfully rolled a complete fuselage out a garage door that is 8 ft 2 in?
Kelly McMullen
PostPosted: Sun Jun 08, 2014 12:16 am    Post subject: Garage door potentially too low Reply with quote
Two thoughts come to mind. Either a motorcycle lift under the nose to lower tail to close to ground, or remove vertical stab.
On Sat, Jun 7, 2014 at 11:11 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=424505#424505
le, List Admin.
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
bob88
PostPosted: Sun Jun 08, 2014 7:33 am    Post subject: Re: Garage door potentially too low Reply with quote
Actually, I am worried about the height of the cabin top. VS is not attached. I am at point of landing gear attach and wondering if I can do that in my garage. I think 8'2" May be typical garage door clearance and a near as I can guesstimate it will be close. Thus would like to hear from someone who has done it (or discovered it couldn't, be done).
Lew Gallagher
PostPosted: Sun Jun 08, 2014 9:49 am    Post subject: Garage door potentially too low Reply with quote
Hey Bob,
With no vertical stab, easily clears 7 feet. I got real good at putting the
vert and rudder on and off with a few bolts to tape off for painting. I did
have to take off the bottom two feet of molding on the single width door
frame sides to clear the wheels with no axel extensions.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
philperry9
PostPosted: Sun Jun 08, 2014 10:45 am    Post subject: Garage door potentially too low Reply with quote
Lew's right.  At a little over 7ft, it's possible.
A couple of tips if you need them for a few extra inches..1) You can disconnect the garage door from the door opener chain/rail and shove the door up a few more inches.
2) You can let some air out of the tires.
3) You can add some weight to the fuselage to squat the landing gear.
You can find quite a few inches if you need to find them.
On Sun, Jun 8, 2014 at 7:34 AM, <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
[quote] --> RV10-List message posted by: <lewgall(at)charter.net (lewgall(at)charter.net)>
Hey Bob,
With no vertical stab, easily clears 7 feet.  I got real good at putting the vert and rudder on and off with a few bolts to tape off for painting.  I did have to take off the bottom two feet of molding on the single width door frame sides to clear the wheels with no axel extensions.
Later, - Lew
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
Kelly McMullen
PostPosted: Sun Jun 08, 2014 7:30 pm    Post subject: Garage door potentially too low Reply with quote
I just checked today. The fuselage, on the landing gear, with engine installed is right around seven feet tall over the doors. So going through an 8 ft tall door would not be an issue with vertical stab removed.
On Sun, Jun 8, 2014 at 11:41 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
A couple of tips if you need them for a few extra inches.. 1) You can disconnect the garage door from the door opener chain/rail and shove the door up a few more inches.
Hey Bob,
Later, - Lew
MS -
e -
Kelly McMullen
KCHD
bob88
PostPosted: Sun Jun 08, 2014 11:11 pm    Post subject: Re: Garage door potentially too low Reply with quote
Thanks guys
Greg McFarlane
PostPosted: Mon Jun 09, 2014 2:39 am    Post subject: Re: Garage door potentially too low Reply with quote
This is how I took 40389 out and back into a 94inch wide garage to trial fit wings/wing root fairings etc,.....sideways with 2 car dolly platforms with castor wheels. Cheers from Western Australia Laughing
 Filesize:  1.49 MB
 Viewed:  7836 Time(s)
bob88
PostPosted: Mon Jun 09, 2014 11:32 am    Post subject: Re: Garage door potentially too low Reply with quote
Brilliant work out in Oz Greg! Thanks for the photo. My problem was just to make sure the vertical clearance would be enough once I have the gear on. At 8'2", seems I'll be OK.
