912 only putting out 12.5 volts
dsingleton
PostPosted: Tue May 27, 2014 5:56 pm    Post subject: 912 only putting out 12.5 volts Reply with quote
My grand Rapids unit shows 12.5 volts. Goes down to 12.3 with radio and transponder on. landing light or strobes take it below 12.0. Installed new regulator( Kawasaki) and new battery. Still persist. Any Ideas ??
Dennis Singleton
davidjoyce(at)doctors.org
PostPosted: Wed May 28, 2014 12:41 am    Post subject: 912 only putting out 12.5 volts Reply with quote
Dennis, have you checked a direct voltage at the battery
to compare? My newly fitted MGL EMS showed only about
11volts, but the battery voltage was 12.9 and there was an
adjustment in the set up program that allowed me to make
the two read identically.
Regards, David Joyce, G-XSDJ
On Tue, 27 May 2014 18:56:19 -0700
Dennis Singleton
http://forums.matronics.com/viewtopic.php?p=423891#423891
Un/Subscription,
Forums!
Admin.
gilles.thesee(at)free.fr
PostPosted: Wed May 28, 2014 12:51 am    Post subject: 912 only putting out 12.5 volts Reply with quote
David Joyce a écrit :
<davidjoyce(at)doctors.org.uk>
Dennis, have you checked a direct voltage at the battery to compare?
My newly fitted MGL EMS showed only about 11volts, but the battery
voltage was 12.9 and there was an adjustment in the set up program
that allowed me to make the two read identically.
+1
Also please give additional information :
- Was your electrical system performing well before ?
- Or is it a new or modified installation, etc. ?
- Is a description of schematics of your power circuit available ?
- Have you checked that your actual installation is in accordance with
the intended schematics ?
- Did you check every connection ?
- Etc..
Best regards,
Gilles
http://contrails.free.fr
