Posted: Mon Jun 02, 2014 8:35 am Post subject: Rotax 914 Turbo Warning Lights |
Folks:
I believe the 912 series engines are primarily oil cooled, with some water and air cooling to help. The engine can be flown at reduced power for some time after a complete loss of coolant without seizing.
Before I sacrificed myself and my airplane, I'd fly to a safe landing area to fix the problem.
MKIII
Near - Burns Junction, Oregon
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Richard Collings
Sent: Monday, June 02, 2014 6:18 AM
Subject: Re: Re: Rotax 914 Turbo Warning Lights
Hi everyone.
I think the experienced pilots amongst our community need to stop this right now and I don’t class myself in that group. Imagine the situation, say on take off, your busy in the cockpit to say the least and you see the engine temp rise into the red,
what do you do, you can’t shut down, you must expedite a safe landing asap. If you have time before the engine seizes try to do an abbreviated circuit and radio your intention with a Pan call and pray you can get back down in one piece. I am sure other pilots will offer differing scenarios. The point is if on top of the considerable work load the pilot has, he now has to somehow manage boiling water and steam in the cabin, he isn’t going to do it.
Sorry for being blunt.
Richard
only 700ish hrs 75 on type
Sent: Saturday, May 31, 2014 2:40 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Thats the whole point right
On May 31, 2014, at 1:46 AM, Brian Davies <brian.davies(at)clara.co.uk (brian.davies(at)clara.co.uk)> wrote:
<![if !supportLineBreakNewLine]><![endif]>
--> RotaxEngines-List message posted by: "Brian Davies" <brian.davies(at)clara.co.uk (brian.davies(at)clara.co.uk)>
When the fluid boils the cockpit could be filled with steam. That would
certainly get your attention!
Brian Davies
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ John Hauck
Titus, Alabama |
Roger Lee
Posted: Tue Jun 03, 2014 5:35 am Post subject: Re: Rotax 914 Turbo Warning Lights |
Your 912 was designed to run at least 30 min. without coolant. Coolant only cools the heads and not the rest of the engine like a car. You can help control temps after total coolant loss by flying at reduced throttle settings. If temps exceed the maximum on the heads the you should have the heads tested for hardness.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
