thottle gadget thingy NOW Rudder cable firewall penetration
rob(at)hyperion-ef.com
PostPosted: Tue May 06, 2014 1:00 pm    Post subject: thottle gadget thingy NOW Rudder cable firewall penetration Reply with quote
Good question, Will.
I too have contemplated what to do about the gaping holes for the rudder cables. I have yet to come up with a solution, though perhaps a modification that uses a short push rod in a bushing through the firewall would mitigate the problem. Otherwise the firewall is the equivalent of crossing your fingers and making a wish that you won’t have flames in the center tunnel.
Has anyone addressed this?
Best regards,
Rob Housman
Irvine,  California
Europa XS
Rotax 914
S/N A070
Airframe complete
Avionics in progress
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: Tuesday, May 06, 2014 12:54 PM
Subject: thottle gadget thingy
I am totally stumped by the throttle thingy...what i am thinking is supposed to happen is that the throttle lever is supposed to move but at least the metal washers are supposed to stay still.
try as I might i cant make the washers stop rotating and as a result it has a tendency to undo the nut holding everything together.
What did anyone else do?
Also in a twofer what about the holes in the firewall for the rudder cables? how are these sealed?
thanks Will
PS this would not be possible on twitter i believe because it only permits 120 characters I believe
William Daniell
LONGPORT
+57 310 295 0744
wdaniell.longport(at)gmai
PostPosted: Tue May 06, 2014 1:21 pm    Post subject: thottle gadget thingy NOW Rudder cable firewall penetration Reply with quote
​is crossed fingers an approved mod i wonder? Smile
It really makes one wonder about all the sealing etc mentioned in the manual
Will
William Daniell
LONGPORT
+57 310 295 0744
On Tue, May 6, 2014 at 4:00 PM, Rob Housman <rob(at)hyperion-ef.com (rob(at)hyperion-ef.com)> wrote:
Best regards,
Rob Housman
Irvine,  California
Europa XS
Rotax 914
S/N A070
Airframe complete
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
thanks Will
William Daniell
LONGPORT
[url=tel:%2B57%20310%20295%200744]+57 310 295 0744[/url]
