rlborger(at)mac.com Guest
Posted: Mon May 05, 2014 7:23 am Post subject: Rotax 9xx oil |
Gents:
This is the oil developed by Shell & Rotax for use in Rotax 4-cycle engines. It's semi-synthetic so it can be used with both MoGas & AvGas.
If you can get it, why use anything else?
Best regards,
Bob Borger
1.09 MB |
3199 Time(s) |
Jim Kelly
Posted: Mon May 05, 2014 7:39 am Post subject: Rotax 9xx oil |
Hi Bob,
It's my understanding that any quality branded 4stroke motorcycle oil is recommended !
rgds
Jim
On Mon, May 5, 2014 at 4:21 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
[quote] Gents:
Best regards,
Bob Borger
_________________ Jim GBWEG |
Posted: Mon May 05, 2014 8:02 am Post subject: Rotax 9xx oil |
Not exactly. There is a list of recommended oil brands and types. It isn't just any 4-cycle motorcycle oil. It has to be non-foaming, with the correct gear lube properties, etc.
AeroShell Sport Plus 4 is made specifically for the Rotax 9xx engines and is the primary, #1, top-of-the-list oil recommendation. Why not use it?
Best regards,
Robert Borger, President
Geowhiziks & Doodlebugging, Inc.
Certified Petroleum Geophysicist AAPG#101
3705 Lynchburg Dr.
Corinth, TX 76208-5331
(H) 940-497-2123
(C) 817-992-1117
On May 5, 2014, at 10:38, James Kelly <europajimkelly(at)gmail.com (europajimkelly(at)gmail.com)> wrote:
| Quote: | Hi Bob,
rgds
Jim
| Quote: | Gents:
Best regards,
Bob Borger
a-List"">http://www.matronics.com/Navigator?Europa-List
//forums.matronics.com
Jim Kelly
Posted: Mon May 05, 2014 8:10 am Post subject: Rotax 9xx oil |
Dear Robert,
Your credentials are advice enough.
Thanks & Best Wishes
Jim
On Mon, May 5, 2014 at 5:00 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
[quote]Not exactly. There is a list of recommended oil brands and types. It isn't just any 4-cycle motorcycle oil. It has to be non-foaming, with the correct gear lube properties, etc.
Best regards,
3705 Lynchburg Dr.
(H) [url=tel:940-497-2123]940-497-2123[/url]
(C) [url=tel:817-992-1117]817-992-1117[/url]
| Quote: | Hi Bob,
rgds
Jim
| Quote: | Gents:
Best regards,
Bob Borger
max8992
Posted: Mon May 05, 2014 9:24 am Post subject: Rotax 9xx oil |
One reason could be : because it’s the most expensive on the French market. I used it initially but changed for Yacco AVX 500 4T which is 15% less expensive and also highly recommended by Ratox.
Max Cointe
mcointe(at)free.fr (mcointe(at)free.fr)
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 490 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Robert Borger
Envoyé : lundi 5 mai 2014 18:01
À : europa-list(at)matronics.com
Objet : Re: Rotax 9xx oil
Best regards,
3705 Lynchburg Dr.
(H) 940-497-2123
(C) 817-992-1117
Hi Bob,
rgds
Jim
Gents:
Best regards,
Bob Borger
| Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Da-List"">http://www.matronics.com/Navigator?Europa-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D//forums.matronics.comD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dot;">http://www.matronics.com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
_________________ Max8992
Europa XS #560 F-PMLH |
Duncan McFadyean
Posted: Mon May 05, 2014 11:54 am Post subject: Rotax 9xx oil |
I suspect motorcycle oil is probably now difficient in ZDDP (anti scuff agent needed if the valve gear, dog clutch etc is to survive), but apparently now depleted because it poisons catalytic converters. Yes, some bikes do have those (eg BMW).
ZDDP is certainly depleted in modern car oil and it's possible (for use with older engines) to buy the stuff separately as an additive.
I started with good quality m/c oil but gave it up because the dog clutch used to screech (you here that alot on shutdown of many Rotaxes). That issue dissappeared as soon as I used the Shell Rotax stuff.
Duncan Mcf.
kennethatkinson178(at)bti Guest
Posted: Mon May 05, 2014 1:11 pm Post subject: Rotax 9xx oil |
I am using Aerolube from Skydrive -advertised for Rotax 912/914????
Ken Atkinson G-CEKV
From: "ami-mcfadyean(at)talktalk.net" <ami-mcfadyean(at)talktalk.net>
Sent: Monday, 5 May 2014, 20:53
Subject: Re: Rotax 9xx oil
Duncan Mcf.
