rv10free2fly(at)yahoo.com Guest
Posted: Sat May 03, 2014 1:51 pm Post subject: RV-10 Air Oil Separator Installation |
Could other builders please indicate if you've gone to the effort of installing an air/oil separator on your IO-540 engines?
If so what is the recommended type and location of same in the engine compartment please?
Any pictures of installations would be greatly appreciated too please.
Warm regards and wishing you all safe skies.
Patrick Pulis
Adelaide, South Australia
Posted: Sat May 03, 2014 3:09 pm Post subject: RV-10 Air Oil Separator Installation |
This is what I'm using. It works. I collect the oil - not return it to the engine. I empty out a couple of ounces each oil change.
Carl
| Quote: | On May 3, 2014, at 5:51 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Patrick Pulis
796 KB |
6423 Time(s) |
Posted: Sun May 04, 2014 4:43 am Post subject: RV-10 Air Oil Separator Installation |
Many thanks Carl & Ashley for your replies.
Warm regards
Patrick
| Quote: | On 4 May 2014, at 8:37, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Carl
<image.jpeg>
> Patrick Pulis
<pre><b><font size=2 color="#000000" face=3D"courier new,courier">
</b></font></pre>
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Mon May 05, 2014 4:43 am Post subject: Re: RV-10 Air Oil Separator Installation |
You might want to check out this thread on VAF that I started on Air oil sep and oil consumption http://www.vansairforce.com/community/showthread.php?t=92980. I have the Anti-splat A/O sep and am very happy with the results. If you mount it on the firewall, be sure to pick up either the cross brace, or support it in more than the two mounting tabs provided. The SS firewall is not thick enough to support the weight of the Separator on it's own. Here is another couple of threads on the subject of installation http://www.vansairforce.com/community/showthread.php?t=42386&highlight=air+oil+seperator, and a photo of my installation.
2.04 MB |
6398 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Tue May 06, 2014 2:20 am Post subject: RV-10 Air Oil Separator Installation |
Bill
Did you also install the 'Anti-Splat' vacuum valve and exhaust port drain tube?
Warm regards
Patrick
bill.peyton
Posted: Tue May 06, 2014 4:26 am Post subject: Re: RV-10 Air Oil Separator Installation |
Yes, I installed the NAPA valve in the exhaust .
WA0SYV
