raymondj(at)frontiernet.n Guest
Posted: Sat Apr 26, 2014 12:13 pm Post subject: OT: power supply noise |
Greetings,
I'm considering putting an unregulated power supply (transformers,
diodes, and a condenser) in an old computer box along with the
electronics to run several stepper motors for a CNC system.
I'm wondering if noise radiated from the power supply will cause
problems for the stepper motor drivers.
Thanks for any brilliant insight or wild ass guesses about this
situation.:>)
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
ceengland7(at)gmail.com Guest
Posted: Sat Apr 26, 2014 6:13 pm Post subject: OT: power supply noise |
On 4/26/2014 3:10 PM, rayj wrote:
Greetings,
situation.:>)
If you're talking about a regular 60 hz line transformer, with properly
sized capacitors after the diodes to filter out the 60 hz AC sine-wave
ripple voltage, you should be fine.
Posted: Sat Apr 26, 2014 7:57 pm Post subject: OT: power supply noise |
At 03:10 PM 4/26/2014, you wrote:
Greetings,
Probably not. Do you have these parts already in hand?
Regulated, clean power supplies up to 350W are pretty
cheap on eBay. I seldom build a supply any more, the labor
alone is more than the cost of an off-the-shelf, plug-n-play
device.
Posted: Sun Apr 27, 2014 6:57 am Post subject: OT: power supply noise |
The parts were part of the CNC kit I bought years ago. It is the power
supply for the stepper motors. The output is in the neighborhood of 5
amps at 38Vdc The kit specified an UNregulated power supply because of
problems associated with back emf from the stepper motors as they
decelerate, as I understand it.
The motor drivers derive the required 5Vdc internally from the power
supply hookup.
My main concern was about radiated noise being picked up because they
are both inside an old metal computer case.
Thanks for the reply.
Raymond Julian
Kettle River, MN
On 04/26/2014 10:56 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Greetings,
device.
Posted: Sun Apr 27, 2014 10:01 am Post subject: OT: power supply noise |
At 09:56 AM 4/27/2014, you wrote:
power supply for the stepper motors. The output is in the
neighborhood of 5 amps at 38Vdc The kit specified an UNregulated
power supply because of problems associated with back emf from the
stepper motors as they decelerate, as I understand it.
Steppers don't generate back emf based on
motion of the moving parts. For the fastest
possible response time, steppers like to be
driven from high resistance if not purely constant
current power sources. It's all about that
t=L/R thingy.
The first stepper systems I crafted used banks
of power resistors to raise power source impedance.
Modern designs will use constant current output
stages in the drivers if they're seeking high
accuracy positioning along with fast response.
| Quote: | The motor drivers derive the required 5Vdc internally from the power
supply hookup.
they are both inside an old metal computer case.
Your application would run quite well from unregulated,
full wave rectified AC as long as the 'relaxed' voltage
is not so high as to place output transistors at risk
in their OFF state.
Posted: Sun Apr 27, 2014 10:28 am Post subject: OT: power supply noise |
Thanks. Now out to the shop!
Raymond Julian
Kettle River, MN
On 04/27/2014 01:00 PM, Robert L. Nuckolls, III wrote:
> neighborhood of 5 amps at 38Vdc The kit specified an UNregulated power
> supply because of problems associated with back emf from the stepper
t=L/R thingy.
> supply hookup.
in their OFF state.
