Dragoon6
Joined: 06 May 2014 Posts: 3 Location: Los Alamos, NM
Posted: Tue May 06, 2014 8:12 pm Post subject: Special Coax Connectors: Apollo Nav/Coms... |
Hello,
I am looking for some (apparently) special coax connectors for my Apollo (now Garmin) nav/coms. The old connectors are made by Delta Electronics Manufacturing Corp., part number 4205018N995-000, and are slip-on on one side with a metal flare to help guide the radio coax connector into place, then a center-wire solder and twist-on shielding connection the other end. There are two rectangular flanges for mounting to the nav/com tray.
I am told that these are standard for the older Apollo radios but they are somewhat difficult to come by. If anyone is selling any or knows of anyone who has any, i would appreciate it.
These connectors float on the tray, which also helps for easy alignment when sliding the radio into the tray. I just need new connectors so I can switch to my RG400 coax from the RG58. Let's see if I can add some photos.
392.11 KB |
4693 Time(s) |
369.33 KB |
4693 Time(s) |
373.25 KB |
4693 Time(s) |
383.44 KB |
4693 Time(s) |
_________________ Travis |
Kellym
Posted: Tue May 06, 2014 8:32 pm Post subject: Special Coax Connectors: Apollo Nav/Coms... |
Why go to all the bother of upgrading to RG400 for nav/coms?? They are
in the 108-137MHz range, where there is not much performance difference
between the RRG-58 and RG-400. Properly installed RG58 with decent
antennas can give over 100nm range. How much more do you need??
KCHD |
stein(at)steinair.com Guest
Posted: Wed May 07, 2014 6:49 am Post subject: Special Coax Connectors: Apollo Nav/Coms... |
Quick hint...you can use the same connector! That said, if you'd like new
connectors we keep them in stock....
Stein
