dean.psiropoulos(at)veriz Guest
Posted: Thu Apr 24, 2014 8:18 pm Post subject: Garmin SL-30 poor VOR reception |
Hello listers:
I have an RV-6A that I've been flying for a few years. When I first started
flying the airplane I did some rough VOR range reception checks with the
SL-30 and I had to get within 20 miles of a VOR station to get the receiver
to lock on and the OBS indicator to stabilize with no flag displayed. I
continued with the flight test regimen and getting familiar with the
airplane and enjoying it. Since flights have been in VFR conditions around
the busy Tampa (Florida) airspace I used the panel mounted moving map
(GPS/Comm) to make sure I stayed out of the Class B, there was no need to
have good VOR reception. The Com portion was the only thing I was using on
the SL-30 and that worked very well. Then, a couple months ago I turned on
the SL-30 and, nothing, no display or Com so I returned the unit to Garmin
for repair. In the meantime I'd been talking to a CFII about working on
my instrument proficiency to get back up to FAA standards after a long
hiatus. When the SL-30 was repaired and back in the instrument panel I took
off on a flight to Ocala to check it out. I climbed up to 4500 feet and
watched the OBS and listened for the ID code as I entered the 40 mile radius
of the Ocala VOR. Nothing so I kept going on a course straight for the
station. Around 20-25 miles out I started getting activity on the indicator
but the flags were intermittent and the radio could not maintain a lock.
Finally about 15 miles out the indicators stabilized and the flags stayed
off, obviously something is amiss.
I'm using a Comant CI-159 VOR/ILS antenna. This unit consists of a phenolic
"puck" with a BNC connector cast into it for the coax connection. There are
two fiberglas elements (thin rods about 18 inches long) that screw into the
puck to form a "V" shaped antenna. I have it mounted on the bottom of the
fuselage in the back of the airplane under the horizontal stabilizer. The
BNC sticks through a hole in the belly and appx 25 foot length of RG-58 coax
runs inside the aircraft up to the SL-30 receiver. No gasket was supplied
with the antenna so I just bolted the puck to the aluminum using the two
bolt holes. After the Ocala flight I removed the puck and elements for
closer inspection and checked the connector on the coax cable at the antenna
end. Nothing wrong that I could tell just by looking at the equipment.
There was a bit of engine oil (from the exhaust) on the puck surface facing
the skin. I cleaned it off and made a gasket to go between the puck and the
skin to minimize the oil build up again. I have not flown the airplane
since but I doubt that lack of a gasket was causing the poor reception,
maybe someone here can tell me. The other thing I checked was the
resistance between the center pin and outside barrel of the BNC connector on
the antenna. Resistance was showing basically a dead short (less than 1
ohm, same reading as touching the meter probes together). I'm not an
antenna designer so I don't know if this is what the reading should be or
not. Aircraft Spruce has the following description for this antenna: " "V"
Dipole VOR/Glide Slope Antenna with detachable elements is similar to the CI
158C-3 with the exception of offering 2-hole mount instead of a 4-hole
mount. This V Dipole encompasses reduced static capability with the use of
P-Stat paint. Integral ferrite balun provides for higher radiation
efficiency." . I don't know if the construction of the antenna would cause
the meter to show such a low resistance, maybe some here could shed some
light on that.
Any ideas, experiences with poor VOR reception here on the list? Since the
radio has been repaired and tested by the factory I'd say it's not the
radio. I checked the connector at the back of the radio tray and it appears
secure so I'm not sure what else to do. Since VORs are being decommissioned
there is going to be less and less need for VOR reception but if I have to
use victor airways during instrument operations I need to have good
reception at the expected range or I won't be able to comply with ATC
clearances. Thanks for the help
Dean Psiropoulos
RV-6A N197DM
200+ hours since 2008
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
Posted: Fri Apr 25, 2014 9:05 am Post subject: Garmin SL-30 poor VOR reception |
I just went and measured the resistance between the center pin and the outside connector on my CI-158C and it too is basically a short, so that part seems "normal". I would do a similar test on your cable with both ends disconnected. That should be infinate resistance.
Are you using "RG-58A" or "RG-58C/U"? "RG-58A" is really lossy. ""RG-58C/U" is better, but still not that great. I would strongly recommend RG-142 or RV-400 for that application. I have RG-142 installed in my RV-8 connected to an SL-30 and to a CI-158C antenna mounted in the top of my vertical stab and I get outstanding reception.
Pull the RG-58 out, get some RG-142 and some high-quality BNC connectors (the crimp-on kind NOT the screw-on kind) and then see how things work. You may still have a problem with the NAV receiver on the SL-30, but upgrading your cable will go a long way in improving your reception in any case.
Matt
At 09:17 PM 4/24/2014 Thursday, you wrote:
Hello listers:
light on that.
Dean Psiropoulos
RV-6A N197DM
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
_________________ Matt Dralle
dlj04(at)josephson.com Guest
Posted: Sat Apr 26, 2014 5:01 am Post subject: Garmin SL-30 poor VOR reception |
Matt wrote:
outstanding
I wonder what the source of that information is. Commercial RG-58A, mil
spec RG-58 (MIL-DTL-17 M17/28-RG058) such as Belden 9203, RG-142 and
RG400/LMR400 are all rated between 3.3 and 4.9 dB per 100 ft at 100 MHz
-- around 1 dB for a practical airplane installation.
Original RG-58 cable was just fine for decades with receivers far worse
than the Garmin. In my experience, connectors are the problem nine times
out of ten. Commercial grade crimp connectors from a manufacturer that
also supplies military grade connectors (Amp, Amphenol, Kings) crimped
with the manufacturer-specified tool checked for the correct crimp
dimensions by someone experienced with this process is the key. Original
military soldered connectors are also OK but only if the installer is
experienced enough to get the dimensions right without melting the
dielectric.
Quick test, after you've confirmed that the cable has continuity end to
end and isn't shorted: grab the cable in one hand and the body of the
connector in the other. Using moderate force, can you rotate the
connector body with respect to the cable? If so, cut it off and try
again, it is not terminated correctly. This isn't the cause of all
problems but is usually diagnostic of whether it was crimped right in
the first place.
