Posted: Fri Aug 22, 2014 6:30 am Post subject: Removable Instrument Panel (was "Engine installation seque |
Posted: Sat Aug 23, 2014 11:21 am Post subject: Removable Instrument Panel (was "Engine installation seque |
The tunnel cover came with the kit .....
I made the 'console' (between the tunnel cover and instrument panel) out of fiberglass. You can buy them from the usual suspects like Aerosport, I think.
I was going to mount various things on the console ..... but only the engine controls are mounted to it so far. My instrument panel and that console were constructed to be removable if necessary .... like CONDITION inspections of the fwd tunnel.
Linn .... windshield fairing #6
On 8/23/2014 12:49 PM, Rob Kermanj wrote:
[quote] Lynn,
Where did you get the tunnel cover?
Thanks.
Do Not Archive.
On Aug 22, 2014, at 9:30 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
| Quote: | Thank you Linn
So, every single wire that goes to the panel has a connector. That triggers a new question:
What was your criteria to group those wires that have a single function, like for example a switch or an annunciator light wire? Did you use 1-wire connectors?
(The picture would be, anyway, good to see that …. J)
Carlos
De: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] Em nome de Linn Walters
Enviada: 22 de agosto de 2014 12:27
Para: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Assunto: Re: Removable Instrument Panel (was "Engine installation sequencing")
Carlos, pictures don't show anything but connectors hanging in the air. All the wiring to the instrument panel goes through connectors on the left side. Antenna cables go direct but have an extra foot of 'slack' to move the panel back for access. The pitot/static/AOA tubes go through quick-connects .... from Home Depot. I did have to grind down the panel where the hand-holds are to clear the rivet tails .... I can't drop the panel down because it rests on a console.
<image001.jpg>
As for your question about the upper fwd fuse section, it slips in really easily and you can cleco everything down. The rivets on the side next to the firewall will become CherryMax. I also did my engine installation with it off so have CherryMax rivets in the upper firewall. I also put the Aircraft Spruce firewall blanket on the inside .... one 4' in front of the pedals and a 2' up top. After I took this pic.
The red fuel selector is Van's selector embedded in flox.
Linn ..... windows/windshield.
On 8/22/2014 6:48 AM, Carlos Trigo wrote:
| Quote: | | Quote: | | --> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt> (trigo(at)mail.telepac.pt) Linn Following similar requests I made to other -10 builders, and obviously beingvery interested in using a removable instrument panel, will you pleasedescribe your solution.If possible, please include pictures. Thanks in advance | 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 5 6 7 8 | Quote: | 9 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 0 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 1 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 2 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 3 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 4 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 5 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 6 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 7 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 8 | Quote: | | Following similar requests I made to other -10 builders, and obviously being | 9 | Quote: | | very interested in using a removable instrument panel, will you please | 0 | Quote: | | very interested in using a removable instrument panel, will you please | 1 | Quote: | | very interested in using a removable instrument panel, will you please | 2 | Quote: | | very interested in using a removable instrument panel, will you please | 3 | Quote: | | very interested in using a removable instrument panel, will you please | 4 | Quote: | | very interested in using a removable instrument panel, will you please | 5 | Quote: | | very interested in using a removable instrument panel, will you please | 6 | Quote: | | very interested in using a removable instrument panel, will you please | 7 | Quote: | | very interested in using a removable instrument panel, will you please | 8 | Quote: | | very interested in using a removable instrument panel, will you please | 9 | Quote: | | describe your solution. | 0 | Quote: | | describe your solution. | 1 | Quote: | | describe your solution. | 2 describe your solution. | 3 | Quote: | | describe your solution. | 4 | Quote: | | describe your solution. | 5 | Quote: | | describe your solution. | 6 | Quote: | | describe your solution. | 7 | Quote: | | describe your solution. | 8 | Quote: | | describe your solution. | 9 | Quote: | | If possible, please include pictures. | 0 | Quote: | | If possible, please include pictures. | 1 | Quote: | | If possible, please include pictures. | 2 | Quote: | | If possible, please include pictures. | 3 | Quote: | | If possible, please include pictures. | 4 | Quote: | | If possible, please include pictures. | 5 | Quote: | | If possible, please include pictures. | 6 | Quote: | | If possible, please include pictures. | 7 | Quote: | | If possible, please include pictures. | 8 |
If possible, please include pictures. | 9
Checked by AVG - www.avg.com
08/23/14 [b]
flysrv10(at)gmail.com Guest
Posted: Sun Aug 24, 2014 5:58 am Post subject: Removable Instrument Panel (was "Engine installation seque |
Thank you. I will check them out.
On Aug 23, 2014, at 3:18 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] The tunnel cover came with the kit .....
| Quote: | Lynn,
Thanks.
Do Not Archive.
Carlos
<image001.jpg>
08/23/14 | 0
