romaine_richard(at)yahoo. Guest
				 Posted: Fri Apr 04, 2014 2:01 am    Post subject: CJ Trim cableCJ Trim cable |
				Some lessons learned...don't use chinese replacement cable (spiral winding
 has a mind of its own and it is brittle) use a similar braided cable (more
 pliable).  When you wind the cable on the spools zip tie it to hold in
 place...and the key item...there is a pulley behind the rear seat bulkhead
 that is removable.   Because it deflects the run in a "v" when it is out of
 its mount you have slack to work with to get everything in place and
 turnbuckles attached.  Once you put it back in position (pin with cotter
 key) you do final adjust with turnbuckle.
 I'm sure you'll get more complete advice...but that's what I wish I knew
 before I started.
 Rich
 Connected by DROID on Verizon Wireless
