bwestfall
Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
Posted: Fri Mar 07, 2014 11:26 am Post subject: C4B5 missing boss mount hole |
I’m using an IO-540 C4B5 off of an Aztec that’s built up as a dummy core for now so I can do the initial cowl and baffling work. The case halves are the actual ones that will be used on final re-assembly of the motor. The issue I’m seeing is a missing boss mount hole for the CB-1002E fwd left support bracket that backs the fwd left air ramp baffling. Has anyone that’s used a C4B5 ran into this? I presume the hole can be carefully located and drilled and tapped but thought I’d ask the brain trust. See attached photos.
Ben Westfall
178.95 KB |
6116 Time(s) |
220.61 KB |
6116 Time(s) |
bcondrey
Posted: Fri Mar 07, 2014 11:45 am Post subject: C4B5 missing boss mount hole |
Yes, I had that on the engine of my first RV-10. My solution was to make a replacement bracket to fit a hole outboard of what was shown in the plans. Picture (fuzzy) attached to give you an idea of what I did. Never heard of anybody else having this issue so I just made a replacement out of 3/4 angle and moved on. Hope this helps.
Bob
On Fri, Mar 7, 2014 at 2:25 PM, Ben Westfall <rv10(at)sinkrate.com (rv10(at)sinkrate.com)> wrote:
Ben Westfall
374.4 KB |
6114 Time(s) |
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Fri Mar 07, 2014 11:54 am Post subject: C4B5 missing boss mount hole |
I also have a C4B5, also missing mounting hole and did the same thing. It's an opportunity to make a part (Fit).
Jim Combs
On Fri, Mar 7, 2014 at 2:44 PM, Bob Condrey <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
[quote] Yes, I had that on the engine of my first RV-10. My solution was to make a replacement bracket to fit a hole outboard of what was shown in the plans. Picture (fuzzy) attached to give you an idea of what I did. Never heard of anybody else having this issue so I just made a replacement out of 3/4 angle and moved on. Hope this helps.
Bob
Ben Westfall
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Posted: Fri Mar 07, 2014 11:56 am Post subject: C4B5 missing boss mount hole |
Bummer. My fellow RV-10 builder found a similar 'flaw' on his case. He elected to drill/tap ..... and found the bottom of the hole isn't far from the inside of the case!!! He'll have to seal that screw well. However, it appears that the 'hole' in your picture is far larger than the screw. I'd clean out the hole real good, fill the hole with JB Weld, re-drill/tap. Use Locktite on final assembly.
Linn
IMHO, of course!!!
On 3/7/2014 2:25 PM, Ben Westfall wrote:
[quote] <![endif]--> <![endif]-->
Ben Westfall
Checked by AVG - www.avg.com
03/07/14 [b]
bwestfall
Posted: Fri Mar 07, 2014 12:20 pm Post subject: C4B5 missing boss mount hole |
The hole you see to the right is not where it goes. That will be filled similar to Bob’s pic once the motor is assembled for real. It’s actually in the boss mount area to the left of the gaping hole. I assume the C4B5 had no reason for an accessory to mount there so Lycoming did not drill and tap that hole.
I did not think about making the smaller front hole work with a custom bracket. I guess I sorta figured that would be used for something else and just dismissed it. Good to know I’ll likely go this route.
Thanks All!
-Ben
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Friday, March 7, 2014 11:56 AM
Subject: Re: C4B5 missing boss mount hole
Linn
IMHO, of course!!!
Ben Westfall
rene(at)felker.com Guest
Posted: Fri Mar 07, 2014 12:30 pm Post subject: C4B5 missing boss mount hole |
I had to do the same thing. Building is fun, I miss is sometimes. But, flying is fun also……
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Condrey
Sent: Friday, March 07, 2014 12:45 PM
Bob
Ben Westfall
bwestfall
Posted: Fri Mar 07, 2014 12:32 pm Post subject: C4B5 missing boss mount hole |
Just for the record the right side has a similar boss mount area that does have holes drilled and tapped thus my assumption was the left side would support it. The attached photo shows the right side for reference. I’d much rather use the existing front hole than risk f’ing up the case that’s for sure.
Again, thanks and glad I asked. I must subconsciously love to do things the hard way as I was pretty much resigned to drill and tap before Bob pointed out what should have been obvious! Ah tunnel vision.
-Ben
Linn
IMHO, of course!!!
Ben Westfall
184.81 KB |
6111 Time(s) |
bwestfall
Posted: Fri Mar 07, 2014 1:06 pm Post subject: C4B5 missing boss mount hole |
For the further record… I checked on the reason for that ½” hole right of the boss mount seeing that Bob’s appeared to be plugged. That is for a through bolt that is just not currently installed on my “fake” motor. Bob’s picture showed what appears as a plug bit is really the back end of a bolt. His case must be an older vintage where the through bolt threads into the case half, newer ones get a heavy nut and washer instead.
-Ben
Linn
IMHO, of course!!!
Ben Westfall
