pjeffers(at)talktalk.net Guest
Posted: Mon Mar 03, 2014 1:01 am Post subject: Europa-List: Europa or Stainless Steel Control Cable |
Hi David,
Whilst I do not disagree with the advantages of plastic tubing being used in this manner, as an inspector who each year is required by LAA to certify the condition of these cables, I have to add that it is impossible to inspect cables that are inside a plastic tube. Those who have gone down this route for protection will be aware of the work involved in gaining visual access to the entire length of cable that lies out of sight.
Pete Jeffers LAA Insp.
Sent: Sunday, 2 March 2014 17:48
One tip for those installing rudder cables in a mono is to
run them inside the light plastic tubing (used extensively
in gliders) through the wheel well. It is virtually
friction free and protects them entirely from damp & grit.
Regards, David Joyce, GXSDJ
On Sun, 2 Mar 2014 08:55:07 -0800 (PST)
Mike Baker <galahav(at)yahoo.com> wrote:
| Quote: | Mil-DTL-83420 is the general spec that describes the
requirements flight control cables
Composition A - Carbon steel, zinc, or tin over zinc
coated
steel cable is stronger and stiffer than corrosion
resistant steel
MIL-DTL-83420/1 - Wire Rope, Flexible, Type I,
Composition A.
M83420/1-005 Indicates - Wire Rope, Flexible, Type I,
Carbon Steel,
Construction; 7 x 19, Nominal Diameter 5/32
Composition B - Corrosion resistant steel
MIL-DTL-83420/2 - Wire Rope, Flexible, Type I,
Composition B.
MIL-DTL-781 - Terminal, Wire Rope Swaging, General
Specification for.
use this info to find the spec of cable you have
the nicopress is usable on either. best to ck spec on
swaging
the best place I know of for flight control cables is
Mcfarlane aviation (USA)
also a good source for other "stuff"
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
To: "europa-list(at)matronics.com"
<europa-list(at)matronics.com>
Sent: Sunday, March 2, 2014 4:14 AM
Subject: Re: Europa-List: Europa or Stainless Steel
Control Cable
Yes, stainless was developed for yachts, sea water
contamination resistant. There isn't much bending in the
Europa so no worries about fatigue.
Must be the multi strand stuff though, 7X19 springs to
mind but anyway it's fine wire strands for flexibility.
Graham
Also be sure you use the right crimps, plated I think,
not plain copper. Get a second opinion, I not as young as
I once was!
To: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>;
Sent: Sunday, 2 March 2014, 6:04
Control Cable
Hi Graham,
Wish I knew if it was what was supplied by Europa. I’ve
had the kit too long to know, things have been moved
around, and I don’t recall the Europa stuff ever being
labelled.
Maybe someone else might be able to clarify. Worst part
is, it looks old even though it mightn’t be. It reminds
me of a Hills Hoist outside clothes line cable, but I
think that is more of an Aussie thing. I actually don’t
have enough Nicopress sleeves now so I’ll need more of
those anyway, so I can get some more pretty stuff
You normally use Stainless Steel cable by choice don’t
you??
TR
On 2 Mar 2014, at 10:18 am, GRAHAM SINGLETON
<grahamsingleton(at)btinternet.com> wrote:
Tony
>I'd say go ahead with the galvanised steel cable. It
>should be fine in Oz, so long as you don't go
>ocean sailing with it!
>Graham
>________________________________
>From: Tony Renshaw <tonyrenshaw268(at)gmail.com>
>To: europa-list(at)matronics.com
>Sent: Saturday, 1 March 2014, 22:49
>Subject: Europa-List: Europa or Stainless Steel Control
>Cable
>Gidday,
>I have gone through my fair share of cable, and
>consequently I have bits everywhere. I have a roll of
>cable which appears to be galvanised, or really dull
>Stainless Steel, which I believe doesn’t happen. Why have
>nice shiny Stainless, if it stains. So, the best advice I
>have to figure out what is what is to use a magnet. The
>unknown roll of dull cable I have is extremely attractive
>to the magnet, and the Stainless is only slightly, but
>still is drawn towards the magnet on a really long
>suspended run, like the length in
the aft fuselage, towards the magnet when it is mm away,
but it still attracts it. So, this other roll I can only
imagine might have been that supplied by Europa, and I
wouldn’t know because this roll has no product code or
numbers on it.
>My question, whilst I’d prefer to use Stainless just
>because it doesn’t look like it has been in the aircraft
>for a million years, however the gal cable (or whatever
>it is) I am told is more durable especially in terms of
>bends. This is a conservative approach from gliders where
>control cabling can have acute bends, but we don’t have
>that. So, should I resurrect this roll of cable out of my
>waste bin and use it, or should I replace it with
>Stainless Steel?
>Thanks for any advice or help, and I appreciate all the
>help I’ve got with this sofar.
>Regards
>Tony Renshawhttp://forums.matronics.com
>href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
http://=======================
