		rmhou(at)yahoo.com Guest
				 Posted: Wed Feb 05, 2014 5:07 pm    Post subject: 50 hours engine inspection |
				In the CJ's "Technical Specifications for Service & Maintenance", for 50 hours engine inspection on page 219, it says:
 "Inspect the tightness for each cylinder with a pressure gauge. Its indication should be 3.5-6 kg./cm2 under a cylinder head temperature of 40-60"C."
 Am I correct to assume it is not talking about a leak down test, but a compression test (like the one I  used to do in my high school auto shop class)?
 If I am correct, 3.5-6 kg/cm2 is 49.8-85.3 psi. I recall using 100 psi as an indication for a healthy car engine when doing a compression test. The 49.8-85.3 psi range seems to be very low. What am I missing?
 Robin
		N13472(at)aol.com Guest
				 Posted: Wed Feb 05, 2014 5:27 pm    Post subject: 50 hours engine inspection |
				The Cj eng is LOW compression That’s why it can burn 70 octane fuel.
 Tom Elliott
 CJ-6A NX63727
 777 Quartz Ave
 PMB 7004
 Sandy Valley NV
 89019
 Cell 541-297-5497
 N13472(at)AOL.COM
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Robin Hou
 Sent: Wednesday, February 05, 2014 5:07 PM
 To: Yak List
 Subject: 50 hours engine inspection
 Robin
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Yak-List  | 	  01234567
 Checked by AVG - www.avg.com
 Version: 2014.0.4259 / 02/05/14
		keithmckinley
				 Posted: Sat Feb 08, 2014 5:40 am    Post subject: Re: 50 hours engine inspection |
				you read correctly.
