Posted: Wed Jan 22, 2014 8:16 am Post subject: Blue Mountain EFIS -Help! |
Does anyone know of any on going set up able to service
Blue Mountain kit? My EFIS Lite G$ has given cracking
service, but alas fell off the bench today, landing on its
back and breaking both airline connectors. It is possible
I could replace the bits myself, but it would be
comforting to have someone who knew exactly what he is
doing on the job! Regards, David Joyce, GXSDJ
rampil
Posted: Sun Jan 26, 2014 7:55 am Post subject: Re: Blue Mountain EFIS -Help! |
Hi David,
Sorry to hear of your mishap.
I think your best bet might be a competent local avionics shop.
The former principal of BMA is off in Thailand at present working on
other things.
I have not ever opened my G4 to examine its internal structure, but with
any luck the white plastic quick-disconnect couplings are attached via
pliable tubing to the transducers.
A drop might have also damaged to MEMS sensors or even the circuit boards.
Does it still power up?
Posted: Sun Jan 26, 2014 9:23 am Post subject: Blue Mountain EFIS -Help! |
Ira, Many thanks for your reply. When I found myself
without a professional Blue Mountain service source I took
the back off and found the offending pieces reasonably
easy to remove. I am waiting for what I hope are
equivalent replacement parts to arrive this week. Whether
its brains have been addled remains to be seen - if so I
guess I shall be rebuilding the port side of my panel as
well as the starboard! Regards, David, G-XSDJ
On Sun, 26 Jan 2014 07:55:43 -0800
"rampil" <ira.rampil(at)gmail.com> wrote:
Hi David,
avionics shop.
present working on
other things.
structure, but with
are attached via
the circuit boards.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=417611#417611
Un/Subscription,
Forums!
Admin.
Posted: Sun Jan 26, 2014 2:13 pm Post subject: Blue Mountain EFIS -Help! |
Best of luck David
Graham
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Ira, Many thanks for your reply. When I found myself without a professional Blue Mountain service source I took the back off and found the offending pieces reasonably easy to remove. I am waiting for what I hope are equivalent replacement parts to arrive this week. Whether its brains have been addled remains to be seen - if so I guess I shall be rebuilding the port side of my panel as well as the starboard! Regards, David, G-XSDJ
