Paul Valovich
Posted: Fri Jan 03, 2014 10:29 am Post subject: Battery or Contactor Issue? |
RV-8A, Z-13/8 architecture with Off-Batt-Batt/Alt switch to get electrons flowing. 380 hours over 3 ¾ years, original Odyssey PC 680 battery.
Flew for 1.3 hours 1 Jan with no problems. On 2 Jan when I turned on Batt/Alt switch, nothing happened. Removed cowl and got out voltmeter – 12.8 volts to hot side of main contactor.
Turned off switch, then back on – same results – nothing.
A couple minutes later as I was digging out the electrical diagrams and references with Batt/Alt switch still on, contactor clicked and system operation was normal with 11.5 volts on the cockpit voltmeter.
I am going to replace the battery, but wonder if there is an issue with the contactor. Tried to search Aeroelectric files for contactor troubleshooting, but couldn’t get system to respond.
Paul Valovich
IYK
Posted: Sat Jan 04, 2014 3:48 am Post subject: Battery or Contactor Issue? |
At 12:28 PM 1/3/2014, you wrote:
| Quote: | RV-8A, Z-13/8 architecture with
Paul Valovich
Unfortunately, you didn't take enough voltage readings.
While the battery master was ON but with the contactor
NOT energized, you needed to know the voltage on the
ground-side terminal of the coil that goes off to the
battery switch.
Had this voltage ALSO been 12.8 volts, then you would
know that causation for failure to close was downstream
of the master switch control path either in wiring, the
switch or it's ground path.
Had the voltage been zero, then you would know that
either (1) the battery-master and associated wiring
was good and (a) the contactor coil had an intermittent
condition or (b) the contactor's moving parts were
'sticking'.
If you could get the problem to duplicate, having
the extra voltage reading would be helpful. A second
reading for contactor coil current would be definitive
too. Put your multimeter in the current mode and use
it to ground the master switch terminal of the contactor
with the master switch OFF. This will emulate the switch
path to ground and will either show about 1 amp of
contactor coil current (coil good, contactor not
closing, therefore sticking) or zero current which
says coil is open. If coil current is good, rap the
housing of the contactor with a screwdriver handle
and see if it drops closed with the aid of some
mechanical encouragement.
Before you replace the battery, it would be interesting
to do a load test on it. Do you have a Battery Minder
or a Schumacher 1562 charger? I would bench charge the
battery overnight and then load test it at 9 volts
to see what the engine cranking dump rate is. 200A
will get you started, 500-700A is what you expect
from a new battery.
This is a classic example of opportunity to make
measurements and KNOW what the problem is before
turning any wrenches. KNOWING the problem is
critical to fixing it with confidence. If you
cannot get it to duplicate for the purpose
of conducting a detail diagnostic, then there
are no concrete assurances that you've identified
and fixed the real problem.
