Another first
teamgrumman(at)yahoo.com
PostPosted: Sat Dec 21, 2013 5:41 pm    Post subject: Another first Reply with quote
I was installing a fuel line on a Tiger yesterday and the whole mechanical fuel pump was loose. It was safety wired, but it was loose. I could shake it. Kind of explains the oil on the bottom of the engine. Fairly new engine too. Note: all case bolts were loose. oil drain back hoses loose.
PostPosted: Fri Jan 03, 2014 11:14 am    Post subject: Another first Reply with quote
Customer came in with a broken aileron bracket. I did the annual almost 2 years ago. Someone else did it last year.
Apparently, the bracket had been broken before and someone glued it back together with contact cement.
When installing the new bracket I noticed the holes drilled obviously wrong. Could explain the problem all along.
 Filesize:  1.82 MB
 Viewed:  2289 Time(s)
