mrspudandcompany(at)veriz Guest
Posted: Sun Dec 29, 2013 1:49 pm Post subject: AeroElectric-List: Re: Source for Relay â?" DPDT (On) Off (O |
| Quote: | >The good things the VPX does for flap control is not allow deployment
>above the maximum flap extended speed
| Quote: | No special changes needed. The wiring shown is
what I suggested earlier . . . a pair of spdt
relays for extend, retract and dynamic braking.
I believe that you could add the feature of not deploying the flaps
above a given airspeed by adding a pressure switch activated by the pito air
pressure system. This would be a normally closed switch inserted in series
between the flap down position switch and its relay. It will then be
adjusted to open at the maximum flap deployment speed. With this mod you
can retract the flaps above the max deployment speed but would be unable to
deploy at the high speed.
Roger
Valin
Posted: Sun Dec 29, 2013 4:15 pm Post subject: AeroElectric-List: Re: Source for Relay â?" DPDT (On) Off (O |
Thanks Roger, that is a viable approach for that feature without the VPX. What I like about the VPX flap control most is just pressing the flap button and it automatically moving to the next programmed flap extension setting. The Legacy circuitry doesn't have that so pilots hold the flap's momentary switch until they get the setting they'd like.
Thanks again,
Valin
